Question about Sport & Outdoor - Others
My trojan platinum treadmill shows a E7 error code. what deos it mean?
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
  • 2072 Answers
SOURCE: Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Posted on Aug 03, 2010
  • 33 Answers
SOURCE: For the trojan solitude 2 platinum treadmill: it
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should hopefully make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: Trojan solitude 2 platinum shows error code E1.
Your problem should be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: I have a steelflex XT-3600
1. If E6 or E7 appears during power on or during operation, turn off and restart
treadmill. If E6 or E7 still appears on the display, turn off and restart treadmill again.
If this problem persists, go to next step.
2. If the treadmill stops at higher level, press "STOP" & "DOWN" buttons at the same
time for 3-5 seconds to reset the elevation motor to bring the unit down to zero
position. Or else, press "STOP" & "UP" buttons at the same time for 3-5 seconds to
bring the unit up to zero position.
3. Turn off and restart the treadmill, the unit should show at 0% elevation and press
Quick start to begin.
Posted on Feb 25, 2011
My trojan treadmill shows an E4 error. What does this mean and how can I fix it?
If you wish to get some details about treadmill error codes ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 29, 2017 | Exercise & Fitness
I have strength master treadmill when I put in on it show me E7 please what is the problem
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
May 03, 2016 | Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
Trojan solitude 2 platinum shows error code E1. How can we fix it?
Good luck.
Jul 13, 2010 | Exercise & Fitness
Sport & Outdoor - Others Logo
351 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
