Ibm infoprint 1145 - 980 service duplex comm.
4 Suggested Answers
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 4 Answers
SOURCE: getting service code 914 on a IBM infoprint 1145
Service code 914 does not exist. If you meant 941, that is a tray 1 lift motor issue.
Posted on Jul 15, 2009
brett207
  • 231 Answers
SOURCE: Error message 917.00 service transfer roller. I
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Posted on Feb 11, 2010
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count
screen.
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Getting service code 914 on a IBM infoprint 1145
Jun 16, 2009 | IBM Infoprint 1145 Laser Printer
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
I am working on a IBM infoprint 1222 it runs single sided copies fine but it jams on the 2nd to 5th page of duplex copies. Replaced the rear exit door and duplex unit but the problem remains. Any help...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 19, 2009 | IBM Infoprint 1222 Laser Printer
IBM INFOPRINT 1352
check for paper jam in duplexer - or it is not seated correctly. power cycle printer after reseating to re-init printer.
Nov 17, 2008 | IBM Infoprint 1352 Laser Printer
IBM 1352 Infoprint
It means it's due for a service, normally the consumables ie fuser, pick up rollers, charge and transfer rollers are coming to the end of their life.
Aug 18, 2008 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Jun 12, 2008 | IBM Infoprint 1512 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
53 people viewed this question
k24674
jasbo
jasbo
