Question about Genius VideoCAM Messenger Webcam
Could not connect pin #0 to grabber - Genius VideoCAM Messenger Webcam
Can i connect a samsung camcorder vdp453 to windows7 pls?
Most of these camcorders do not have proper usb support for video, so you'll have to buy a so-called video grabber or capture card. You can plug in the video grabber to usb and then connect dvi or firewire from your camcorder. Install the included software, configure your camera. Then press play and the video grabber will record the input from your camera.
When you buy one of those video grabbers, make sure it's a good one. Make sure powerful and stable software (which is compatible with windows 7) is included. Cheap things usually don't work. I've had this Chinese piece of junk for $10 which lagged and kept crashing my computer. Pinnacle was a lot more expensive but it works great and the fun will last a long time.
Jun 17, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Installing the 2.0 e750 video grabber and getting a picture
I also have this problem with the E750. i only have 2 audio out connectors and a scart connection on my video. how do I connect a video lead to my pc.
Sep 06, 2009 | Toshiba Satellite L350-ST3701 Notebook
Could not connect capture pin to grabber for genius webcam
You might have another type of applications such as MSN messenger open.
Thank You!!!!
Jun 23, 2008 | Computers & Internet
Power for HP554e
I will try to help you. Locate a 10-pin connector below your backup battery. This connector has only 9 pins. It has four pins on the top and 5 pins on the bottom. Connect connector from your power button to the top row pins 6 and 8. Look at the diagram below I marked connection points with the “+” sign.
2 4 6 8
0 0 + +
0 0 0 0 0
1 3 5 7 9
Just for your references. Pins 2-4 for Power LED, 1-3 for Hard Drive LED, 5-7 for Reset Button.
Regards
May 23, 2008 | Cornerstone FIC AM37-L Socket A XP...
i suggest you uninstall previous driver. Then restart your pc and re-install again your web cd driver then re start pc again
Jan 10, 2008 | Genius VD3000022 Webcam
Webcam not working
My web cam isn't working don't know why or what to do?
Dec 15, 2007 | Computers & Internet
Genius VideoCAM Messenger Webcam Logo
274 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
