Question about Microsoft USB Slim Multimedia Pro Keyboard (SKB2200U)
Windows XP start in safe mode with F8 not possible. What is wrong?
  • SINN3D
    SINN3D Oct 07, 2010
    Can you please explain in further detail?
  • 477 Answers
You are to slow, you must hack constantly in beginning on F8 to get in in safe mode. also try to get in BIOS with DEL button or F10, F2 depends what kind of computer your have. if that doesn't work, it seems like keyboards not supporting bios.
Posted on Oct 07, 2010
Toshiba satellite is stuck safe mode it's running Windows XP.I tried restart f8 start normal a black screen with bunch stuf& starts in safe mode. What's wrong how can I get it out of safe mode?
First you should really consider upgrading from Windows XP because it is no longer supported and the chances of your computer becoming infected are extremely high.
Pressing the F8 command will only access Windows RE where you can access startup repair safe mode etc.
If the computer is only allowing you to go into safe mode that is a good sign that something is severely wrong with your OS.
While in safe mode you should try and access system restore, but this will only work if 1) you have turned on system restore and 2) your system has a restore point to access.
Have you added any new hardware or programs to the computer? If yes, then the new addition may be the cause of this issue. You can use device manager to rollback any changes or access programs and features to delete any program changes.
Other then that, if none of the above suggestions work I would strongly suggest booting from the disk media to access Windows RE too recovery the computer or just to re-image the computer.
Hope that helps.
Nov 08, 2015 | Toshiba Computers & Internet
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
Safe mode on a computer
When you start the PC, as soon as it hums up start hitting F8 button. The black window with a bunch of safe mode options will show up, select the one you need.
Aug 27, 2014 | Microsoft Windows XP Home Edition
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
When the laptop is switched on it goes to the page with start windows normally. when i select it, it goes to the starting page of window xp and then restarts again.
I would suspect damage to the file system and possibly something wrong with your hard drive. Windows loads a number of system files during bootup, and when it cannot find or read these files, it will cause Windows to repeat the process and cause the bootup loop that you are having.
First thing, backup all your data if possible. Second, you can try pressing F8 when booting the computer to access the "safe mode" boot menu. Once in the "safe mode" boot menu, select the option "Last good configuration", and see if the computer boots up.
There are more complicated methods if that does not work, but its the first thing I would try.
Mar 02, 2011 | Compal EL81 Notebook
Unable to open defragmentation because missing file MFC42u.dll
Restart in Safe Mode and perform the defragmentation in Safe Mode.
Starting your computer in Windows XP Safe Mode can help you diagnose and solve many serious problems, especially when starting normally is not possible/Just before the Windows XP splash screen shown above appears, press the F8 key to enter the Windows Advanced Options Menu.
Jan 21, 2011 | Dell Dimension 1100 PC Desktop
How to start in safe mode?
While the computer is initially booting up, press F8 (repeatedly if necessary), you should be presented with a selection screen to boot into safe mode (various levels such as with or without networking) or to boot normally. The F8 key only works while the computer is going through the BIOS startup procedure.
Jan 03, 2011 | HP Pavilion a1719n (RQ403AA#ABA) PC...
How to open in safe mode
Turn on the PC - as soon as the BIOS screen dissapears keep tapping
F8 - this will bring up the boot menu and let you select "safe mode".
If you get to the Loading XP screen with the moving bar you pressed F8 too late, reset and try again.
Jan 25, 2010 | Microsoft Windows XP Professional for PC
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
Microsoft USB Slim Multimedia Pro Keyboard (SKB2200U) Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
