Question about Canon Cameras
My a72IS camera is not recognised by my usb port . I have tried both windows XP and windows 7
    Brigadier General:
  • 11,967 Answers
Try using a card reader instead of the camera.
Posted on Oct 07, 2010
Windows 7 doesnt recognise USB cable for traveler dc-6300 what I need to do
The official specifications for the camera don't state it is compatible with windows 7. A few things you can try to connect:
  • change the usb port you are plugging into.
  • try a different usb cable if you have one available
if neither of these things work you might be better off purchasing a card reader that is compatible with windows 7. these can be found for relatively little money. Then you can put the SD card from the camera into the card reader and download photos that way.
Mar 01, 2011 | Cameras
It dont recognise the usb port it says make sure it connected. It works fine on my window xp.This is window 7 laptop,
try running your windows 7 in XP mode. Check the SInger Futura support website. I know they have some patches to run on the newer versions of Windows.
Jan 05, 2010 | Singer CE-200 Quantum Futura Computerized...
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
My usb cable is not being recognised I have to put memory card into my kodak and up load onto compu that way, i've removed and reinstalled using disc supplied with camera but still with no success, i even...
Try using a different USB port. Sometimes the camera is not probably installed if you use the "wrong" port. After the camera has been recognized you should be able to use any port.
Oct 14, 2009 | Fuji FinePix S1000FD Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
