Question about Stairmaster 4600 Cl Cordless Freeclimber
Right pedal sticking down when pushed down happening more & more
    President:
  • 2,777 Answers
It may simply need some lubrication on the join where the step attaches to the main machine unit. I assume you have probably tried this though, please let me know and I will keep helping.
Thanks
Tim
Posted on Oct 07, 2010
  • 503 Answers
Take side panels off, you have on the right side the alternator on top, middle pulley and bottom eccentric hub assembly on each side of the pedals are return springs disengage them. their a braket that holds the alternator loosen bolt so that the Poly-V Belt can be removed. Now inspect by hand if thier is a slippage both ways on the eccentric Hub assembly if so replace the eccentric hub assembly .
Please post your feedback and Vote if the problem resolved as per your satisfaction.
What is the solution to stop idle car racing?
Spring on throttle body is not working. Or, throttle plates sticking, clean them. Or Accel cable sticking. Have someone push the pedal while you look for the problem under the hood.
Jun 01, 2014 | 1994 Mazda MX-6
Clutch pedal sticks and trouble shifting
It happen twice to me ,spring come out from clutch disk and jam the pressure plate, check transmission shift very well with engine stopped, When you push the pedal you push the spring and put pressure on the disk
Mar 30, 2014 | 1999 Chevrolet Camaro
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
On a 2005 chevy suburban my brake lights will come on after about 4 seconds but not right away. I would assume there is a sensor near the pedal. What do I look for and how do I check it?
the brake light switch is near the brake pedal it should have a wire (or wires) attached to it, it is activated when you push the brake pedal in, they are usually spring loaded & it could be sticking just give it a spray with WD 40 & see if that fixes it, if not it may have to be replaced.........hope this helps.......cheers.
Sep 16, 2011 | 2003 Chevrolet Suburban 2500
Brake lights stay on permanently on 97 ford escort.
the cause is the brake light switch on the backside on top of the brake pedal. it is either out off adjustment or it needs replaced. this switch activates the brake lights when pushing on brake pedal. if it gets out of adjustment or sticks the brake lights will stay on because it does not cut voltage to brake lights. have a good day !!
Apr 21, 2011 | 1997 Ford Escort
Clutch sticking will not go into first
Ok it looks like there is no problem with the clutch or tranmission. You problem is that the clutch pedal is stiff and sticking to the floor. This sometimes happens when vehicles sit for extended periods of time. It might free up by working back and forth by hand. Have the vehicle off and the parking brake applied and push the clutch pedal up and down with your hand, It might stick to the floor and you may have to pull it off the floor a few times. You can also get some spray lubricant from your local canadian tire or auto parts store. open the hood and have someone move the clutch pedal up and down and spray the moving parts. It might take a few times to free up the stiff linkage but it will work :)
Mar 07, 2011 | Nissan Se R Cars & Trucks
Manual Transmition, While driving the clutch pedal went right to the floo and stayed down. I lifted the pedal with my foot and with a light touch i pushed down on the pedal and it it began a grinding sound...
the slave cylinder on the trans works just like a brake cylinder, when fluid pressure is applied it flows into the cylinder and pushes against a clutch fork which engages a throw out bearing against the clutch pressure plate fingers. a couple things could have happened. I think your trans is fine but im sure the clutch fork or the pressure plate broke. I'm sorry but the trans is gonna have to be pulled. best wishes
Feb 03, 2011 | 2000 Isuzu Trooper
Stop lamp switch how do you adjust this
the stop light switch is spring loaded & pops out when the brake pedal is pushed in & pushed in when the brake pedal returns you need to adjust it so as in is pushed right in & lock it in that position, then check if the brake lights come on when the pedal is pushed in you may have to re adjust it to get it right.....hope this helps.....cheers
Jul 26, 2010 | 1997 Hyundai Elantra
Brake lights stick on
It sounds like the brake light switch down on the brake pedal is stuck and it needs replaced,Its got like a push button setup when you apply the brakes the brake pedal pushes the brake switch button in brake lights come on and when you relase the brake pedal the button on the switch comes back out and brake lights go out but if switch is worn out or sticking the lights will stay lit even when off the brake pedal so just replace the brake light switch down on the brake pedal.
Apr 20, 2010 | 1992 Dodge Dakota
Suzuki VL intruder 125 back brake sticking and braklight stuck on
i too had this problem .....dnt worry just remove the brake cable and lubricate it with some spray like ABRO or WD40 lubricating spray then you sprayed some in the cable.play with it pull it forward and push it backward.,lubricate and repeat the steps till you find the cable goes smoother...you know it usually happens due to dust and dirt which enters the cable n get it stuck,try this n tell me..
Mar 26, 2009 | 2003 Suzuki VL 125 Intruder LC
Open Questions:
Stairmaster 4600 Cl Cordless Freeclimber Logo
41 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
