Question about IBM IntelliStation Z Pro 6221 PC Desktop
I need a network driver for my ibm intelli zpro 6221.
  • 25 Answers
Please follow this link for your Ethernet Driver from IBM:
http://www-947.ibm.com/support/entry/portal/docdisplay?brand=5000008&lndocid=MIGR-5079975
I beleive you need the bottom one (intc_dd_nic_15.1_windows_32-64.exe)
Download it, and run this .exe file.
This support's ALL IBM systems.
Hope this helps, and please don't forget to rate ^^, Thanks!
Posted on Oct 07, 2010
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
I have IBM Intellistation Z Pro 6221. I tried to install XP, I press F6 for SCSI driver. Then It prompts Press 'Enter' for install or 'R' for repair. Whatever I press it displays No hard disc detected
You need a floppydisk including the Driver for the SCSI or Sata drive - Depending which HD You are using.
If the controller is in motherboard You will find the driver from motherboard webpages.
If it's a separate controller card - You will find it from it's web pages.
XP doesn't support too well sata if it's not the XP SP3 version media.
You may need to change the sata to compatibility IDE mode to get it up and running.
Jan 06, 2011 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM Intellistation z 6221-3m8 computer
It will run faster only if the applications are multi-threading capable. Nearly all older apps cannot take advantage of multi-threading, but some of the newest apps are starting to be coded to take advantage of multiple cores/threads. You may also have to update the OS for it to recognize the second core.
Feb 07, 2010 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM IntelliStation Z Pro 6221NNG upgrade possiblity
This: http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx is a link to the system requiements. As for memory, I can't find out if it's DDR or DDR2. If you don't know either, try downloading a tool called CPU-Z. That should display DDR or DDR2, and I can then recommend something.
As for the graphics card, you could try to get an ATi 9000 series card somewhere.(maybe buy one on ebay? I doubt they still sell them new...) I have one too, in an old PC, and while it doesn't run any new games, it's fast enough for the casual user.
Dec 07, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
My USB ports suddenly quit working on my IBM Z Pro 6221 59U
Check the actual ports, visual inspection. Look for consistancy of the pins, and guide. If one is bent or missing, that can short out the ports, or blow out the integrated circuit.
If you are using a usb keyboard, try to start up and go into the setup using the keyboard. If you can, the driver for the ports might be damaged, causing the problem in windows, but not in the bios startup.
You can purchase a usb board that can give you new ports, and deleting the usb hub from the hardware manager (check help) and re-detecting the device might repair a damaged driver.
Sep 23, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
The computer turns on but there is nothing coming on the screen, its not the video card because i just bought a new one to put in
Hi..
Besure that the video card you inserted are correctly inserted you need to check it first. You need also to installed the vieo card driver. If the sam things occurs you need to disassemble the unit . Try to remove the proccessor and clean it after that insert it again. Check all the power cord and cable wire if it is correctly install in their respective port.
Thanks for using fixya..
Regards
ICmanServer
Aug 05, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM IntelliStation Z Pro 6221 PC Desktop Logo
144 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
