My Bosch MAXX WFL2260 washing machine has stopped working, drum does not turn or spin. belt is ok, does brushes need changing if so how?
  • landmorewest Oct 07, 2010
    The drum rotates freely by hand.
  • 11,896 Answers
If the belt is good and motor spins, then the drum bearings are bad. Try spinning the tub by hand. It should spin freely if the bearings are ok. If it does not spin freely, then the bearings are likely bad.
If you have removed the belt from the motor and tub and motor is not spinning, then the motor is likely bad. You can check the power to the motor with a voltmeter to see if it is getting power.
Posted on Oct 07, 2010
  • Nate Stansfield
    Nate Stansfield Oct 07, 2010
    Try removing the belt and see if the motor will spin when it's turned on. If not, check power to the motor. If there is power, then motor is bad. If no power to motor, then control panel or timer is having issues.
My bosch max wfl2260 gets power, however nothing happens on whichever cycle is selected. the machine takes in water but then just stops. water does not drain unless you select drain on the machine.
hello do you mean the drum is stuck if so check the belt at the back of the washer it might have snaped or come off if this ok then the cause could be the brushes on the motor hope it helps
regards
shaun
Mar 27, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
How to reset the error codes (F21) on Bosch Maxx 7?
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Oct 10, 2009 | Bosch Washing Machines
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
