Question about Lexmark E232 Laser Printer
Printer not printing
I have jsut installed a Lexmark E232. I have conencted it to my laptop with a USB cable and have been able to successfully install the printer and set it up as my default printer. All very exciting, however i cannot print any documents! The printer is connected correctly, has sufficient paper and has a new toner cartridge. The paper jam light (4th light down) is lit up however no other lights are lit up or flashing to explain the paper jam issue. I have opened the front part of the printer and have also removed the paper tray and found no traces of a paper jam. Please help. Is there a paper jam or is there another error that needs adressing?
Many thanks,
Katrina
  • jsprague80 Jun 20, 2008
    my printer tries to run however it will lift the paper like it is trying to feed it and then it stop and display paper jam
  • Anonymous Mar 19, 2014
    will not print don's see paper jam
    Master:
    Sergeant:
  • 461 Answers
You might need to check your driver if it is install correctly for the correct OS, i'm not sure what OS you are using but below link might be helpful to help solve your issue
http://etech.maiila.com/?p=42
all the best..
p/s please rate me...
Posted on May 29, 2008
I am trying to install my Lexmark E232 printer on my WinXP 64bit Notebook with 64bit drivers. The printer is installed via USB on my network PC which uses 32bit WinXP OS. I can see the printer but I cannot...
Please try to use the 32 bit PCL 5 Emulation Universal Print driver which is available for download from support.lexmark.com website.
For additional assistance, please contact Lexmark Technical Support.
Jul 20, 2011 | Lexmark E232 Laser Printer
\i need to connect lexmark E232 laser printer to HP desk top computer but printer cable does not fit computer. what do i do?
most printers now use USB2 for the input. It is a square looking cable. Now, most pc's have a standard USB 2.0. It is a flat rectangular looking cable. You need to find a cable that had one of those on each end. I should have come with one.
Mar 03, 2011 | Lexmark E232 Laser Printer
How does one print address to a number 10 envelop in the Lexmark e232 envelop slot?
If you go into Printing preferences before you print, you want to go into the tab that is calle dsomething to the effect of Paper/Quality. Look for the section called Paper Option. Under paper option there should be a part that lets you choose the paper size, there is where you can choose Envelope #10. Make sure also you have the Lexmark Universal Driver installed for this printer.
Feb 28, 2011 | Lexmark E232 Laser Printer
Can not seem to work with usb connection
Please try to switch to another usb port or if you have an extra usb cable, try using a different usb cable. After changing port or usb cable, check if printer shows on device manager and make sure printer is set as a default printer.
For further assistance, please contact Lexmark Technical Support.
Dec 13, 2010 | Lexmark E232 Laser Printer
Page Count Report for a Lexmark E232
Print test page direct from a printer - press Continue ("Diamond button").
Nov 23, 2009 | Lexmark E232 Laser Printer
I have a Lexmark E232 LaserJet printer that stopped printing because it has run out of memory. What do I do?
An isolated print job may be so intensive that it consume all of the memory available on the printer but that would have to be a seriously intensive print job.
Once that job is flushed from the printer, following jobs should be fine.
However, if you have a block of memory failing, you may have to replace the memory chip.
You could print the printer's menu settings and see how much memory is installed in the printer.
Don
Apr 24, 2009 | Lexmark E232 Laser Printer
Printer is "offline" and will not print
turn the printer off remove ink cartridge refix it again.then check.also check ther eis not any paper jam in printer.
Jan 05, 2009 | Lexmark X7350 All-In-One InkJet Printer
Lexmark E232 Laser Printer Logo
214 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
