Question about Stairmaster 4400CL Stepper
Right side pedal sticking when pushed down - Stairmaster 4400CL Stepper
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: right pedal sticking down when pushed down
It may simply need some lubrication on the join where the step attaches to the main machine unit. I assume you have probably tried this though, please let me know and I will keep helping.
Thanks
Tim
Posted on Oct 07, 2010
Emergency brake pedal stuck won't release, there is no release pull, the pedal is push down and push down again to release won't go down any farther to release! stuck on the side of the road right now
Start the vehicle, and while pushing down on the break put the vehicle in reverse and gently use accelerator to go back an inch or four. If that doesn't work continue to rock the car back and forth until the ebrake cuts loose
Mar 26, 2016 | 2004 Nissan Quest
What is causing a creaking, squeaky noise to come from the right pedal on my sc5?
Your transmission chain and reduction pulley, and or step chain need to be checked.
It could just be the transmission chain is on just a little too tight, causing the creaking or that the step chain/s just need a little grease on them (which is likely the culprit to any creaking).
If you find you need need any further assistance we would be happy to help you out :) by chat at www.sportsmith.net or by phone at 888-713-2880
We look forward to hearing from you if you need us!
Aug 12, 2015 | Stairmaster Exercise & Fitness
Why noise in car when pressing on gas pedal grinding
It's the car pulling to that side? Sticking brake pad possible. When did you have brakes done last off at all? Front brakes go out twice as fast as rear brakes. If you can Charlie jack up that side put car in park, set emergency brake and chock rear tires. Pull off that tire and see if rotor is grooved or scored badly. It may have been sticking and wore down faster. Also check CV BOOT. If torn u joints get dirty and will grind. Hope this was some help.
Feb 05, 2015 | 2005 Chrysler Pacifica
OK 2000 Tahoe brake pedal switch which wire color is hot wire and witch wire color should feed power to brake light when you push pedal down. Also the colors at switch do not match color at bulb!
ok so unplug the thing and stick a voltmeter in it, the hot side is obvious-if neither side is hot then you know you need to start troubleshooting the circuit-I would start with the brake fuse.
Jan 31, 2015 | 2000 Chevrolet Tahoe
Brake lights stay on permanently on 97 ford escort.
the cause is the brake light switch on the backside on top of the brake pedal. it is either out off adjustment or it needs replaced. this switch activates the brake lights when pushing on brake pedal. if it gets out of adjustment or sticks the brake lights will stay on because it does not cut voltage to brake lights. have a good day !!
Apr 21, 2011 | 1997 Ford Escort
Just bought a used model singer 6233 need to know where foot pedal plugs in
The Singer 6233 was one of the models that briefly were made using air-powered foot controls. So you aren't looking for a traditional electrical connection. Instead, your pedal cord's female end will connect onto a black male nipple, that sticks out on the right side of the machine (the side with the handwheel). Just push it on until it feels snug.
May 10, 2010 | Sewing Machines
Brake lights stick on
It sounds like the brake light switch down on the brake pedal is stuck and it needs replaced,Its got like a push button setup when you apply the brakes the brake pedal pushes the brake switch button in brake lights come on and when you relase the brake pedal the button on the switch comes back out and brake lights go out but if switch is worn out or sticking the lights will stay lit even when off the brake pedal so just replace the brake light switch down on the brake pedal.
Apr 20, 2010 | 1992 Dodge Dakota
Suzuki VL intruder 125 back brake sticking and braklight stuck on
i too had this problem .....dnt worry just remove the brake cable and lubricate it with some spray like ABRO or WD40 lubricating spray then you sprayed some in the cable.play with it pull it forward and push it backward.,lubricate and repeat the steps till you find the cable goes smoother...you know it usually happens due to dust and dirt which enters the cable n get it stuck,try this n tell me..
Mar 26, 2009 | 2003 Suzuki VL 125 Intruder LC
69 mustang brakes
one of two things. first you need to make sure the star adjuster is adjusted the same on both sides. the reason is that when you hit he brake the right side is trying to stop you and the left side isn't.. or you brake line or wheel seal on the right side is sticking..i would try to adjust the little star spinner i think thats your problem..good luck keith...
Mar 15, 2009 | Ford Mustang Cars & Trucks
Wheel sticking on peugeot 406 on a p reg
The brake hose maybe bad replace it. They can claps on then self inside the hose. One work to check is have someone push the brake paddle down and release it if the rotor is hard to turn, open the bleeder vale if fluid comes out and the rotor turns freely that you problem.
Mar 05, 2009 | Peugeot Liberte Cars & Trucks
Stairmaster 4400CL Stepper Logo
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
