Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Only one headphone works
Hello, the problem with my sansa is that only one of the headphones work...I know I should fine someone to fix it, but I do not know where to start. Can you help me?
  • lunilulu May 29, 2008
    Just to complete my case...unfortunately, I bought a refurbished device...sansa would not make a repalcement, they sent some files to see if with that I can solve my problem with the hardware.
    Thanks for your help!
  • 8,596 Answers
I would find out if you're in warranty. One headphone working is a hardware issue - if you were to insert another headphone set into your player, you would find that the next headset would only get sound out of one ear. Unless you live in Philadelphia, I would go ahead and call Sandisk to see if you are eligible to get that player replaced. I work for another large consumer electronics company, and we definitely give out replacements for the one- headphone-only issue. Sorry to hear that the player went out on you - good luck on the replacement.
-Tha Mp3 Doctor
Posted on May 29, 2008
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
Sansa clip headphone jack -- headphones work fine on other players or phone, but clip plays only one ear. If i jiggle the headphones thingie inside of jack i get sound in both ears sometimes. 1) Any...
the jack inside the unit either is bad or the solder connections are bad...you can re-solder the jack(if you know how to solder) and see if this fixes it...or else you'll have to replace the jack(which may be avail. through Radio Shack)
Jan 14, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa will only play through the right speaker/headphone unless you jiggle the cord and hold it in the perfect spot, then it will play through both speakers/headphones. Is there a way to fix this...
This is a common problem, it is the lead in the headphones get a new headphone set that will sort you,IF it is the actual jack, soldered onto the motherboard, this then will required to be resoldered. I think, however just replacing them will work fine.
Apr 01, 2010 | SanDisk Sansa e260 MP3 Player
Only the left ear phone works
Try updating the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
Sound only in right ear
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
May 03, 2009 | SanDisk Sansa e200 MP3 Player
Headphones
This is a common issue with Mp3 players - the headphone jack is damaged, and must be replaced. Sansa will not sell you just a headphone jack, and there are no repair services, so the entire player must be replaced.
Jun 14, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa e250 MP3 Player Problem
convert the songs to mp3 or just delet all of your song and try again it worked for me
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
Headphones
The headphone jack is loose from the circuit board.
If its less than 1 year old, SanDisk will replace it.
Otherwise, you can take it to a electronics repair shop, or someone who knows how to solder.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e130 MP3 Player
Headphones only work if they aren't fully in
Its a problem with the jack on the circuit board. If its less than 1 year, SanDisk will replace it. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 18, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
