Question about Ahead Software Nero 6 Ultra Edition (2434nl20) for PC
Nero 6 burning rom inconpatible with windows 7
    President:
  • 2,340 Answers
Nero 6 is not compatible with Windows 7
Nero 9 is compatible.
You can check Win 7 software/hardware compatibility @ Windows 7 compatibility center.
Hope it helps
Posted on Oct 08, 2010
Unable to copy music to cd by using nero7
First you need to locate your music/audio. If it was downloaded from Limewire/Frostwire the default location would be C:\Documents and Settings\**Your Username**\Shared
You can also access your music/audio through Limewire/Frostwire, by going to your Library, then highlighting a file that you want to burn and press explore. This will open the folder containing the highlighted file.
Alternatively use the search to search for something you know is in the folder you want to access or eg. search for the extension of the music/audio you want to burn.
First it may be worth mentioning that there are two ways of burning audio in Nero 7. Using Nero Express or Nero Burning ROM (The original Nero program). I find both very simple to use, but prefer Nero Express, so That's what I will use here.
First open Nero StartSmart:
Pressing add is not necessary. You can also open folders outside of Nero Express, and then you drag and drop the same way.
You can make mp3 disks using Nero Express as well. Just choose make Data Disk instead of Audio CD in Nero StartSmart. The only difference you will see is that instead of minutes you will be adding size (MB)
In case you run into playback issues when using Nero Express, then you have two options. You could try using Nero Burning ROM. Raaf explains here how to do that with Nero 6, but Nero 7 is very similar:
Burning a (audio) CD from your MP3's (Windows)
Another way is to run a tool called CD/DVD Drive Speed (can be found in Nero StartSmart under Tools, where you let Nero burn test disks for checking the best speed for this type of disk.
Aug 03, 2012 | Ahead Software Nero 7 Essentials Suite...
Problems with nero 6
once you finish the burning process the nero wont close or exit.it will be running in system tray.
in your system tray right click the nero icon and click exit
Dec 25, 2007 | Computers & Internet
I have Nero-burning rom and have been using it successfully with Windows XP for the past two and a half years. The disc will not load in my NEW computer using Windows 7. Please help. Regards, Hamilton
first u must check if the disc still in good condition (sometimes the problem is the disc is already damaged)..
if the disc not broken try to explore it and find the setup application then run it. if its doesn't work maybe your windows 7 is installed with 64bit system and i think nero 5.5 is not compatible with 64bit system.
maybe u need up to date software ( nero 7 above)..
hope this useful.
Feb 15, 2011 | Ahead Software Nero Burning ROM 5.5 Full...
My pc is not booting so is their any solutions for that. i need instructions for making a bootable XP without nero. becoz i dint have a blank cd wih me right now, to write a cd
You can't boot Windows XP from a floppy disk the way you used to be able to with DOS. One handy way to easily boot XP is by using a USB flash drive. Here's how to make it work. Boot Windows XP from a USB flash drive
Aug 24, 2010 | Computers & Internet
Dvd rom cant read cd/dvd
It may be that its went to meet is maker,and you will have to replace it .If its prone to dust or smoke you could try cleaning it .If you use Nero Burning Rom,look inyour Start Menu/All Programs/Nero. In the sub menu click on Nero Tools and then select Nero Info Tool and see what that brings up.Hope this helps.
Regards Bill
Feb 19, 2010 | IBM Computers & Internet
Have Nero 7 essentials, all music files are not burning correctly, when they are played back from the burned cd, music files skip and music sounds distorted. When I burn the same music files from my lap...
Sounds like your Nero ASPI file is corrupt download a new version HERE
Replace you original DLL with the one above and restart Nero ROM this should solve your problem.
Jan 02, 2010 | Ahead Software Nero 7 Essentials Suite...
Nero - Burning Rom has a known compatibility issue with this version of Windows. For an update that is compatible with this version of Windows, contact Ahead Software.
If your trying to install Nero 6 on a Vista there is no point as it does not support Nero 6, your better off installing Nero 8 or 9 as Vista does support them.
Regards
Jun 21, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Uninstalled nero 7 to put nero 6 back on but it's not working!!
Did U Checked ur Windows - Is it Vista - ?
If not Something got wrong n Now u have to delete the folder of Ahead From C:
Now Reinstall Applpication u might find the reason and the Thing -
Jan 15, 2009 | Ahead Software Nero 6.0 (60045) for PC
Ahead Software Nero 6 Ultra Edition (2434nl20) for PC Logo
192 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
Tony
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
