Question about Kitchen Ranges
Small rubber ball come out off heater tank obvously some valve or overload can you advise
    President:
  • 2,047 Answers
Usually the small rubber ball is used as the stopper to regulate the flow of water into the tank. This stopper acts as a pressure guage which shuts the water flow when it gets to the recommended limit. Usually i would advice you shut down the entire unit from the mains. Then open the heater tank usually the ball is supposed to have a space for a screw then you can screw the ball back into the lever which is inside the tank and regulates the flow of water. But in the other case where the lever is spoilt you would need an expert to replace the entire control mechanism.
In general the only offside to this ball pulling out is that the unit is prone to overflowing water when the water is coming into it.
Hope this solution has been helpful?
Posted on Oct 07, 2010
Water system problems
- normally water tanks are mains fed so the auto shut valve for the water tank could be faulty but more often than not, it will overflow the tank through natural wear of the washer. the auto shut valve is normally some kind of ball **** valve.
Aug 22, 2016 | Water Water Heaters
WOULD SOFT WATER HAVE A BAD EFFECT ON THIS MODEL AS IT HAS RUSTY BITS
Hot water heaters are a collector of sediment. The proper care includes flushing out the collected debris through the low side drain faucet. The problem is the faucet is not designed correctly to carry out the needed task. If you are handy... turn off the water and gas or electricity to your water heater. Relieve the water pressure through the temperature/pressure relief valve on the side of the water heater tank. Once pressure is relieved close the valve. Determine if you have a 1/2 inch or a 3/4 inch diameter drain valve hole in the side of the tank where the drain valve is located. The drain valve can be removed with channel lock pliers, an 8 or 10 inch adjustable wrench, or a small 8 to 10 inch pipe wrench. Water will leak out the threaded hole while the valve is out. If everything is closed maybe 2 cups of water will leak out of the hot water tank as you check drain valve thread size. DO NOT take your time checking thread size. After you know the pipe thread size go to the hardware store ( Home Depot, Lowe's etc) purchase a short nipple (1 1/2 to 3 inch depending on available space) and a ball valve (brass) due to the water temperature. You will also need a brass adapter for pipe thread to garden hose thread (male both ends). This adapter goes into the ball valve to allow for the connection of a garden hose. Connect the pipe and valve together using the correct pipe thread sealant and install in place of the original plastic drain valve. Install pipe to hose adapter using thread sealant. With the ball valve in place turn the water back on. Gas or electricity back on. Connect a garden hose to the ball valve. Place the other end of the garden hose in a safe area as hot water and debris will be expelled through the hose. With water on, Gas or Electricity on and the relief valve closed actuate the ball valve to the full open position for approximately 3 seconds then close the valve. Repeat the open and close of the ball valve three times. Observe the debris that emptied out of the garden hose. You may be surprised at what you see. If the water runs clear, disconnect the garden hose the task is completed. You can wait until the following year to repeat the process. Your pipe and valve are now a part of the water heater, they may remain in place. Put the hose away.
Aug 31, 2015 | Water Water Heaters
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Cistern
The arm controls the Flush Valve. Inside the flush valve is a black rubber "seal" that closes the end of the fill pipe and stops the water. If a piece of sand, grit, or small rock gets imbedded in the seal it will allow water to pass through even when the tank is full. Either you take apart the flush valve and remove the grit, or you replace the whole valve. Sometimes even when the grit is removed the rubber seal is damaged and must be replaced. A new valve, and some of these replacement seals can be purchased at a good hardware or plumbing supply store. Use the valve handle, below the tank, on the pipe that comes through the wall, to turn off the water before replacing the seal or valve.
May 26, 2013 | Home
Are there always 2 tanks in the loft for baxi boiler 401
No this small tank fills your rads tank must be half full , remove wire let tank fill up change ball valve if it does not shut off , bleed all your rads with the pump off , then run rads to heat up then bleed again .
Feb 09, 2013 | Heating & Cooling
Central heating boiler will not heat heating water
first do not call engineer go up in loft if there is a lot of insulation in loft have some boards to lay down in loft you will have two water tanks one large and a much smaller one look inside the smaller one and if the ball valve is stuck in the upright position and no water in tank move ball up and down water should flow wait for tank to fill then bleed radiators with a small key obtainable at most diy stores for this you will need a small towel with key hold towel under valve loosen the screw at top of radiator air will escape then water will escape do this to all radiators repeat this a second time so only water comes out turn on heating system also there is a chance you will have to turn down heating system
Dec 02, 2012 | Water Heaters
The liquid in the top tank will not come out is there anything I can do to fix that thank you
This is a common problem with this unit. For unknown reasons the tank stops dispensing water. A new upper tank is usually required.
Jan 25, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Water comming outof the smal air intake valve on top of tank
Check the shut-off valve on the tank to make sure it's shutting the water supply off as it should. If the tank has a mechanical arm(the flush lever), check it to see that it is allowing the shut off valve to completely shut the water off.
Aug 18, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
