Question about Konica Office Equipment & Supplies
Konica minolta c452 . noise from the fusing section .replaced fuser but noise comes back after +- 1500 copiers .comes and goes
  • Konica Master
  • 6,161 Answers
There are several different noises associated with the fusing unit Konica Minolta even came out with the different sound each can be a different part or problem have KMBS Tech look at!
Posted on Jan 17, 2015
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
jqsababa967
  • 145 Answers
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Posted on Dec 03, 2008
I have a C - 3921 trouble code in Konica Minolta c451
Replace the fusing unit. Reset the copier power off the machine, with the utility/counter depressed power on until trouble reset appears, touch it see OK. Power off wait 10 seconds power on. if no code ok, if code re-appears do NOT Reset, machine is telling you it is broke if you reset again it can catch on fire the code you are messing with the is the fuser the hot part, it will ruin a perfectly good day. Get fuser replaced. about 800.00
Feb 27, 2015 | Konica Minolta Bizhub C452 Copier
C-3B02 in bizhub c452
This going to get expensive, could be any of the following the IH coil unit or IH Power supply unit. This series of machine uses a magnetic field to produce heat for the fusing process the process of fusing the toner to the paper, any way the code you have is stating the IH pwr sup or coil unit are not talking to the copier cpu. It could also be a relay board between the cpu fuser system, worse case the image control board. I would go with fuser power supply. Just my humble opinion.
Jan 30, 2015 | Konica Minolta Bizhub C452 Copier
C452 water toner
replace the waste toner box lower section below toner section is in front of the image units
Apr 30, 2014 | Konica Minolta Bizhub C452 Copier
Error code c-3b02
The Fuser Magnetic High Current Assy. is bad not the fuser but the section it plugs into. located below the control panel behind a cover.
have a tech come out. Try this one time if the code comes back do above do above if do it again the fuser can catch on fire that will ruin a perfectly good day
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Feb 14, 2014 | Konica Minolta Bizhub C452 Copier
TROUBLE CODE C173
Have a tech come out re-flash th copier os and also check the NVRAM board firmware, mite also be the control board
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
BizHub C452 shadow printing
Recommended replacing the fuser unit. or is the color off not laying on top?
Jan 15, 2013 | Genuine Konica Minolta Konica Minolta...
Error c-3425 on bizhub c452
hi
in table number vg blak unit image is 914
i replase unit image blak developing tank
please help me
Nov 15, 2012 | Konica Minolta Bizhub C452 Color Copier,...
Konica Minolta bizhub c452 makes clicking / ticking noise. also has color streaking.
The ticking noise your hearing is VERY common on the C452, C552 & C652 models. Normally it is accompanied by a slight squeak that will get worse as well. There are numerous articles that cover this but the ticking is either coming from the fuser drive assembly (just inside the right hand door on the right below the exit drive assembly) or the exit drive assembly itself. If your mechanically inclined the problem can be found with one of the gears being worn on the shaft it turns on and becoming oblong. You will need to contact a service tech or dealer for parts since you can only get them from Konica. I hope this helps!
Sep 14, 2012 | Konica Minolta Bizhub C452 Copier
My konica 4355 is showing f36-1 error what could be the problem
Fuser Section overheaded (HOT SECTION) can be reset in 25 Mode. If it comes back Fuser needs replacement part(s)
Feb 24, 2010 | Konica Minolta Office Equipment & Supplies
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
161 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
