Question about Microsoft Windows Vista Home Premium Edition for PC
I was delet java and than I can't instant java in my widows vista
When i am installing yahoo messenger during installation an error comes d3d9.dll not found reinstall it........now what can i do plz help me.........
ANY Yahoo! Messenger program will not install properly if a former program, or an incomplete install, has not been completely deleted from the computer first. (Don't worry - your Contacts List will be saved into the fresh installation of an updated Messenger!)
Delete all Yahoo Messenger references from the registry.
  • Use the Control Panel > Add/Remove Programs method,
  • Then double-check by going to Start > Search > files and folders > Yahoo! Messenger (notice the exclamation mark in the title).
  • Write down and delete all references manually if necessary. The uninstaller works well for Vista and Win 7, but not for XP - it leaves behind MANY junk files when uninstalling.
  • If you are using Internet Explorer 8 or 9 as your browser, Yahoo Messenger 10 will not work properly without Flash and Java programs installed, and possibly the .NET framework update. (Messenger 11 is still in beta format, so be wary of using it yet.). you'll have to download Flash and Java programs as well.
Last, you could used this link to fix a dll error:
http://fix-all-dll-errors.com/d3d9.dll/
Just click on the link, then click the button "Fix dll errors now." This should fix the issue. Hope this helps. Thank you for using FixYa!
May 20, 2011 | Yahoo Messenger
I have Instant messenger widows problem can't see what I have written other what the other person has written?
Open internet Explorer > Click on Tools > Choose Internet Options > Click on Advanced > Check in "Browser" option here for "Disable script debugging(For internet explorer) or (For other)
If the check box is not ticked. just make it ticked and save. Now try Exit and restarting Yahoo messenger.
If still not working, Update Java and Adove flash player plug ins.
I hope it will work.
Thanks for joining us. Have a nice day.
Jan 14, 2011 | Yahoo Messenger
When I send an instant message to someone they can see me type but the message never get to them. If they are on my friends list they seem to get the messages. I updated Java and my messenger to the latest...
it can be fixed through deleting extra key in registry settings. navigate to HKEY_CURRENT_USER \Software \Microsoft \Windows \CurrentVersion \Internet Settings\ then delete keys other than 0,1,2,3,4 get someone who knows around windows registry to set it right..goodluck
Dec 31, 2010 | Computers & Internet
Why my pc cant display instant IM from yahoo messenger
Your problem is with Internet Explorer - even if you do not use it and have another browser set as default. IE plays an unseen but essential part in the operation of Yahoo Messenger
Keep your IE updated - the latest version is 8 for Vista and XL
You may have scripting disabled in your Internet Explorer.
To enable scripting:
Launch IE
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messeng...
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Dec 21, 2010 | Yahoo Messenger
When i type in chat i can not see the words in chat window
Launch IE
Click "Tools"
Click OK
Click OK
Restart IE
Java installation problem
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
Error: 25099 during Java installation This article applies to:
  • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
  • Browser(s): All Browsers
  • Java version(s): 6.0 , 6u10+
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Nov 08, 2009 | Computers & Internet
Java won't load on my computer
id suggest that you uninstall java and delete the folder from the hard drive after you uninstall it from the computer, and then clean the registry of any instances of old keys associated to java,then redownload and reinstall java fresh,be sure its the right version for your Vista ( home,Bussniess) Hope this Helps Steve
Oct 01, 2009 | Computers & Internet
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
  1. Go to Java.com
Sep 17, 2009 | Microsoft Windows XP Professional With...
I have vista. I have the java error 20599. I have deleted everything including the folders and I am still getting the error!! Help!
Try rebooting into Safe Mode (press F8 immediately after the bios screen, but before the Windows progress bar begins), remove all versions of java. Proceed to http://www.java.com/en/ to install the latest version.
Sep 06, 2009 | HP Computers & Internet
Microsoft Windows Vista Home Premium Edition for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
