Question about Dometic Rooftop RV Air Conditioner
Trips the breaker on the trailer when the heat strip is turned on
  • 59 Answers
You have an electrical short, it some time forms at the heat strip after years of use the small wires break and cause a short. You need to replace the heat strip, and or it might be a bad breaker. There is really need no other reason for the short.
Posted on Oct 07, 2010
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
Tempstar 2400 blows the a/c breaker when heat is on
How long before the breaker trips?,does the a/c work ok,gas heat or heat pump?,electric strip heat on auxiliary heat,if these are shorted they will trip a breaker,if the breaker trips instantly you have a dead short in the system,if it runs for a while it may be a weak breaker,you may have a bad compressor if it trips fast or a shorted out heat strip,need more info!
Mar 08, 2013 | Heating & Cooling
I purchased a 5ton goodman heatpump 6 years ago. the breaker for the heat strips keeps tripping, which a service technician changed last year because it was doing the same thing. The heat strips only come...
Hi, sounds like you could have a couple of problems. If the breaker is tripping when the strips are calling, they are drawing more amps then they should. The data plate on the unit will tell you the Amperage rating of the heat strip package that is installed and should match that of the breaker. Since the breaker was replaced I would recheck how tight the wiring is at the breaker as they will lossen up do the the heat they are pulling. Make sure they are tight both at the breaker and at the strips, just turn the breaker off and check this. Also, the strips should energize when the thermostat needs them to help out the heating cycle. It is good you can manually turn them on, but you shouldn't have to. I can not guide you through the process of checking T-stat operation as I would need to be on site to see how they wired it at the unit and stat.If it has always worked this way then this is most likely the way the installer wired it. If not, you will need to have the stat checked out. I would consentrate on solving the breaker problem. Just look at the data plate for the strips amperage and see if it matches the breaker amps. Tighten these connections and I bet this will solve the big problem. If you had a clamp around amp probe and with some help from me I could guide you on how to do an amp check to see if its the strips, wiring, or breaker by doing a amperage check. Tighten up all the connections and keep me posted for more help. I will be here to help you solve this.
Good Luck,Shastalaker7
Jan 11, 2010 | Heating & Cooling
Every time my heat pump turns on, the blue auxilliary light comes on, and it only blows icy air. I do not want to use that much power, so I turn it back down a few degrees. Now, it is 50 degrees in the...
A heat pump starts losing efficiency below 30F or so. The aux. heat helps the heat pump keep up with heat demand. The Aux heat can be electric heat strips or another type of heat. Check to make sure you have power to whatever type of aux heat you have (breaker not tripped, no overloads tripped). If it is electric heat check the heat strips to make sure they haven't burnt in to. Hope this helps.
Jan 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
My electric furnace keeps tripping the breaker , it will run for about five or ten minutes then trips.
If you dont have an ampmeter it is hard to tell whats going on. First check the breaker and see if it is getting hot. If so turn off power get a screwdriver and check to see if wire are tight on the breaker. Loose wires cause breakers to trip. If the unit has ran before and it has not tripped the breaker and it hss just now atarted replace breaker but do not put a larger one in. Check the size of your heat strip in Kw or what they call for on the size of the breaker. 10 kw no larger that 60 5kw no larger than 30. 15 kw has a 60 amp and a 30 amo circuit. Let me know whats going on.Rus
Dec 07, 2009 | Refrigerators
I have a Rheem Warrior Class Model 72-52-2 240/208 wattage, manufature date 9-2005 in a trailer house. The breaker keeps tripping. When I reset the breaker, it will heat for a minute and then trip again....
Yes it is most likely shorted out to test remove the wires after you have disconneted the breaker turn off the water and drain water then remove it and replace it.
Sep 30, 2009 | Water Heaters
My electric trips out when I switch the tumble dryer on
Sounds like the plug cord is wired wrong on the dryer, or the breaker is too small or going out. Or the heat strip could need to be replaced.You should have a 30 amp breaker for the dryer. Check the heat strip then your breaker.
Sep 02, 2009 | Hotpoint Dryers
30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Mar 05, 2009 | Weather King 10AJA2501AH Air Conditioner
Kenmore dryer trips the breaker
THE PROBLEM COULD BE THE CONNECTION TO THE BREAKER ITSELF , BREAKERS ARE SET UP FOR CURRENT OR AMPERAGE SURGE AS WELL AS THERMAL IF THE WIRE CONNECTING TO THE BREAKER IS LOOSE IT WILL HEAT UNDER LOAD AND CAUSE THE PROBLEM YOU DESCRIBE , TURN OFF THE BREAKER AND RE TIGHTEN THE SCREWS AND IF THE TERMINALS ARE DETERATED MIGHT NEED TO REPLACE THE BREAKER IF POSSIBLE CUT THE DAMAGED PORTION OF THE WIRE CONNECTING TO THE BREAKER STRIP THE END AND RECONNECT
Dec 21, 2008 | Danby DCD5505W Electric Dryer
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
70 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
