Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Our Panasonic TH-50PX600A/S has stopped working. It was turned off for the night on standby mode and the next morning it would not work. The red LED light is flashing at a cycle of 10 flashes. I have turned the main power off several times but when you try and turn it on, it does not start and you always get the 10 flash cycle on the red LED.
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
micromaster
  • 3614 Answers
SOURCE: panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
Posted on May 18, 2008
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic TH 42PA25. Front power switch LED is solid red. SC Board LED (D6583) is not lit. SS Board LED (D6765) is not lit. However, SS Board LED D6769 is lit. I suspect PA or P board.
The TV is on standby mode due to protection; some error in the board. If you have spare boards, try replacing it one by one, starting from display board.
Jul 28, 2012 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Tv wont turn on< red power light just keeps blinking?
I have the same thing. Just started blinking 10 times. Pretty much had to unplug the unit over night. Could never turn it off and then turn it on again.
This worked for about a week. This morning, tried to turn it on after being unplugged. Still blinks.
Called Panasonic. they attempted a couple solutions, nothing. Suggested authorized repair shop.
Aug 20, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Oct 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
133 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
