Question about Philips Senseo HD-7810 Coffee Maker
When i switch on the machine, the water spills over and doesn't go through the coffee pod
  • 24 Answers
A number of options here:
- The seal is damaged or malformed. It should be flexible, round and bent inward without cracks or tears,
- The coffee pad has come between the seal and its seat. Make sure the pad is centered properly before closing the lid,
- The pad holder is bent or warped. Replace it or experiment with the other one you have.
Posted on Oct 28, 2010
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Sep 07, 2014 | Gaggia Classic Espresso Machine
Why would my keurig only push through a small amount of water from a pod but give a full cup when using a fill your own pod?
Hmm, this is a very interesting question. My experience tells me it is probably two things that are happening with your Keurig. It takes a bit more air pressure to push the water out of the heater through a new pod than pushing it thorough a do-it-yourself pod. This would have to do with how much coffee is in the new pod, vs. your own pod and the grind of the coffee. My guess is that the grind in the new pod is finer than the grind you are using in yours. Anyway, the issues are probably experiencing are either a weak air-pump motor "and" a leaky solenoid valve, or a combination of both. The air pump motors are notorious for getting all rusty and corroded on the inside due to water leaking from a bad solenoid mounted directly above it. Once the motor armature starts to get rusty it starts to lose power because it doesn\'t spin freely anymore. In addition, the solenoids used on this machine are also notorious for leaking and the internals become corroded. Once the inside of the solenoid becomes corroded it gets sticky and will not firmly seat closed during the brew cycle. If the valve doesn\'t close all the way it will allow some of the air from the air pump to bypass the water heater and flow into your external water reservoir. During the brew cycle of a new pod do you notice any air or water draining back into the external water reservoir? If so, you have a leaky solenoid. Bottom line is, if you are not a technical person, you\'ve got big problems with your machine. This explanation is getting a bit long and boring (I know), so if you want to know your options to fix it or return it for a new one, you will have to send me another note. The repair is a pain! Good luck and I hope this helped.
Aug 05, 2014 | Keurig Platinum B70 Coffee Maker
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
What are coffee pods? Someone told me to use them in my coffee machine?
Some coffee machines have the option to either use ground coffee and filters or coffee pods. These are small, sealed containers that have the ground coffee inside. You insert the pods into the machine and click them into place. The machine pierces a hole and the water drips through. It's a much tidier way to make coffee especially if you don't drink a lot of it, so you don't want a whole jug full, rather just one cup at a time.
Feb 25, 2013 | Home
My b-40 Keurig doesn't make coffee it draws the water and despences it back into the water well. It doesn't come thru the coffee pod.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 05, 2011 | Keurig Elite B40 Coffee Maker
When i place pod into machine it doesnt have any water or coffee come through when i switch it on
A few initial steps:
  • Insure that the water reservoir is full, and that the machine is plugged in.
  • Check the water inlet tube for kinks.
  • Ensure that you are using the correct portafilter or insert for ESE pods.
Here is a link to the manual.
Krups contact:
Phone: 1-800-526-5377
Monday through Friday 8:00 AM to 9:00 PM EST
Saturday 10:00 AM to 2:00 PM
Mar 03, 2011 | Krups XP4030 Espresso Machine
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
Cuisinart EM 200
I was about to abndon pods on this machine, and then I actually used the Pod filter basket - it worked like a charm. Decalcifying is not a bad idea.
Jan 22, 2009 | Cuisinart EM-200 Espresso Machine
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
Philips Senseo HD-7810 Coffee Maker Logo
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
