Question about Dualit CTS4E 4-Slice Toaster
The toaster is only cooking on one side - Dualit CTS4E 4-Slice Toaster
Your toaster is broken. Use common household tools to fix it. In the end it should toast on both sides.
Posted on Aug 08, 2015
U have a broken element on one side. You may be able to look inside and see the broken element. If not take the ends off it may be there. No matter it is a broken element. Keep looking for the broken element it may be slightly tacked to each broken end but not good enough to allow enough current to pass through.
Posted on Oct 07, 2010
    Problem Solver:
  • 8 Answers
It could be that your toaster was recalled due to a safety defect. I'd recommend browsing this list of recalled toasters to see if yours is on there: http://wemakeitsafer.com/tools/recalledproducts.php?type=Toasters%2FToaster+Ovens
Posted on May 05, 2011
Where can i find replacement control knobs for the front of the oven
Farberware FAC900R Toaster Oven with Repair Questions ...
www.fixya.com/support/...farberware_fac900r_toaster_oven_with/page-9
Recent Farberware FAC900R Toaster Oven with Convection Cooking ... How do i find a replacement for the timer control knob for the toaster oven K4245H?
Oct 15, 2015 | Farberware FAC900R Toaster Oven with...
I need the toaster oven manual...where can I get one?
Hi Sharan try this link
http://documents.holding.no-ip.ca/cooks-toaster-oven-manual.html
Oct 04, 2015 | Cook's Essentials To67pblk Toaster Oven
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
For HB 22708 Toaster Oven: Will it toast both sides of a slice of bread at the same time?
Yes, the Toastation works like a traditional toaster in the top slots. If it is not toasting both sides like a regular toaster then there is a problem. If that is so and if it is still under warranty, then contact the company for repair. If it isn't under warranty, then find a local repair business.
Mar 29, 2011 | Hamilton Beach 22708 Toaster Oven with...
The left side slots will not lock in the down position to cook the toast what can I do?
There may be a broken wire inside on that side of the toaster as if all power were out, neither would lock in the down position...
Best Regards
Ck
Jan 05, 2011 | Cuisinart CPT-140 Cool Touch 4-Slice...
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Ttm602 toaster,browning one side ,even on highest setting , of 5
The problem is with the heater (bars) connection, which would be under the cover on the left side. Caution ! You're dealing with electricity which may cause a fire. That said, the solderless connecters on the heat elements and the wires probably need replacing,that's all,I did it to mineand it worked. DON'T forget the caution!!!!
Sep 10, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Halogen light heater
I have same problem Took whole unit apart found upper bulb is connected with wire that goes through out. You hve to physically take bulb out through side without electronic panel wire is connected on panel sid with actual plug. but ended up cutting wire other side. Bulb is not like regular bulb you will have to hard wire one side of it. bulb is unseperable from wire. Still looking for replacement bulb. I sure miss my toaster I believe it will probably be chaper for me to buy new toaster vs replace bulb. The bulb is nothing like I have seen before.
Nov 03, 2007 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Dualit CTS4E 4-Slice Toaster Logo
627 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
