Question about Aiwa XD-DV370 DVD Player
Doesn't do anything
The green light shows up but on the screen all the lights light up and that's it.
  • 1 more comment
  • sarah_davies Jun 29, 2008
    My much loved Aiwa XD-DV370 was working happily yesterday playing a region 1 DVD, but today it won't start up and shows 4 8s on the display, the four characters looking like an 8. I have had it quite a while but really don't want to replace it.
    If anybody can help, I'd be very grateful.
    Sarah, Leamington Spa, England
  • Anonymous Aug 05, 2008
    My Aiwa XD-DV370 dvd player has been working for years. I unplugged it on July 20 for a week. Plugged it back in and tried to use it a couple of days ago. The green light comes on but nothing else. After randomly pushing different buttons all of the display lights come on and nothing happens. I had to remove the cover to get my Netflix dvd out. How do I fix this?
  • davedunk Sep 03, 2008
    My XD-DV370 has worked for about 7 years with no problems. Whilst watching a DVD recently the DVD stopped ( paused ). I could not do anything. No buttons responded. I turned the DVD of at the mains and back on again. The power light came on but nothing happenned. I pressed the eject button a couple of times and then all the display lights came on and I was still unable to get anything to work.
Saeco Philips coffee machine display screen doesn't light up? I can still use it and I can see the options but with no colours.
I can still use it and I can barely see the options but display screen doesn't light up
I'm having it sent back for repairs, is there a quick fix for this issue so I do not have to send it back
Apr 11, 2013 | Saeco Intelia Focus Automatic Espresso...
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
My webcam doesn't work. The green light shows up next to it, but when I come to view through the camera all I can see is a black screen. It literally doesn't show anything, even lights.
Hi cazjenks...
Try this solution to your problem
Follow the instructions below to use your webcam
Click on Start then >Control panel>hardware and sound >device manager>imaging devices>web cam....enable it
Another way is to use a IM application like Yahoo messenger,NetMeeting,etc. They will have video capabilities that will work with your webcam.
Please take time to rate me thumbs up
Sep 10, 2011 | Computers & Internet
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
ViviCam
Do you have a viewfinder and a screen? The screen won;t show anything if you have the viewfinder turned on.
Jun 18, 2008 | Vivitar ViviCam 5100 Digital Camera
Aiwa XD-DV370 DVD Player Logo
57 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
