Question about PfaFF Creative 7570
Sewing How do get my ends to stay together when i come to a ending point and raise the sewing foot to cut the thread? Yes i am a man trying to sew. actually i am in the starting point of my lingerie lines... I sketch just about every thing.and why not put it to use on womens sexy lingerie. Who knows i might make it big some day.......... Hope some one can help with my starting point......making the ends stay together...... Thank you Troy
  • Troy Sykes May 30, 2008
    Well i guess some how the nickname came up
    as lingerie ......
    That's wrong on that part........
    Any way i am using a old singer sewing machine
    and i don't think it has a reverse.It is actually my grandmothers
    and i re did the wiring so it can be used.....
    sure enough it works....but what it does that i am not
    sure yet......If i could sew like i sketch i would have a whole
    fashion line going .......Thank's for the fast come back on
    my situation.........
    Hey every one can call me Troy
    See ya........
    New Friend:
  • 184 Answers
Troy Try reversing 3 stitches and back over 3 stitches then lift the foot.
Posted on May 29, 2008
Keeping the thread in needle when you begin to sew
after threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
Nov 03, 2015 | Sewing Machines
How do I adjust the timing on Brother inovis 1500 sewing machine?
Clean the machine, especially the bobbin and bobbin case area and around the feed dogs. Take all the thread off the top of the machine, including thread off the spool pin. Raise the presser foot. Rethread the top with the presser foot UP, which lets the thread get between the two tension disks. Put the foot down to sew, and hold the ends of the bobbin and top threads together behind the presser foot for the first 2-3 stitches in each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551 I'm betting you're seeing something like the last two pairs of photos.
May 22, 2014 | Brother SE-270D Computerized Sewing...
Machine is binding up
New needle, right way around, and thread again from scratch, manual in hand. Make sure you're threading with the presser foot up. Raise the bobbin thread. Start each and every seam thus:
1. Place the work under the needle. Use the handwheel or needle up/down function to drop the needle into the fabric.
2. Drop the presser foot.
3. Hold the bobbin and top thread ends together and take about 3 stitches.
4. Drop the thread ends and sew normally. See also: http://www.picturetrail.com/sfx/album/view/22521551 last pair of photos.
Apr 28, 2014 | Euro-Pro 9105 Computerized Sewing Machine
HOW TO THREAD THE BOBBIN ON THE BROTHER VX-1250!
Hello
Place a spool of thread over the spool pin, which is a vertical spoke located at the back-right of the top of the sewing machine.
Take the end of the thread from the spool and carry it left along the top of the machine and around the bobbin winding tension disc, which resembles a small button.
Pass the end of the thread through the small hole in the side of an empty bobbin, threading from the inside. Push the bobbin down onto the bobbin winding shaft, which is a small metal spoke at the front-right of the top of the sewing machine.
Click the bobbin over to the right, then manually twist it in a clockwise direction until you hear the spring on the bobbin shaft click into place.
While pinching the end of the thread that is coming out of the hole in the side of the bobbin, slowly press your foot down on the foot controller so that the thread from the spool winds around the bobbin. Let go of the thread end and continue pressing until the machine stops automatically, which means the bobbin is full, or when the bobbin has as much thread as you need for your project.
Cut the thread connecting the bobbin and the spool, and trim the thread end coming out of the hole in the side of the bobbin. Click the bobbin over to the left and remove it from the bobbin shaft.
The Lower Thread;
Turn the balance wheel (the disc at the top of the right side of the sewing machine) toward you to raise the needle to its highest point. Lift the presser foot with the lever located behind the needle shaft. Remove the extension table, if it is attached.
Open the shuttle cover, a small door located on the front of the sewing machine, underneath the needle. Remove the bobbin case, which you see held in the center of the shuttle race, by pulling the hinged latch on the front of it.
Pull about 4 inches of thread from the bobbin and press the bobbin into the bobbin case so that it will turn clockwise when you pull on the thread end. Slide the thread into the slot on the side of the bobbin case, over the tiny tension spring and into the delivery eye.
Hold the bobbin case by its latch so that the metal finger is pointing upward. Press the bobbin case -- with the bobbin inside -- into the shuttle race. The metal finger should fit into a vertical notch at the top of the shuttle race, and the bobbin case should be held securely in place.
Close the shuttle cover.
The Upper Thread;
Rotate the balance wheel toward you until you see the take-up lever raised to its highest position. The take-up lever has a metal loop at the end of a narrow spoke, and it will emerge from the top of the thread guide, the vertical **** at the front of the machine above the needle.
Take the end of the thread from the spool and take it left along the top of the sewing machine, around the rear thread guide, then toward yourself and around the front thread guide.
Take the thread down the front of the machine and from right to left around the tension control dial, which is the round knob to the right of the needle. Pull the end of the thread so that the part that passes around the tension control dial is taut and flush with the front of the machine. You should feel the thread slip between the two tension discs.
Carry the end of the thread upward from the tension control dial and through the eyelet at the end of the take-up lever. Bring the thread downward and hook it behind the thread guide, which is a small wire loop at the top of the needle. Insert the thread end through the eye of the needle from front to bac
Pull a tail of about 4 inches through the needle and pinch the end of it with your left fingers. Turn the balance wheel toward you with your right hand until you see the needle lower through the needle plate then rise back up again. You should see the lower thread looped around the upper thread. Untangle it and pull both thread ends until they have approximately 6-inch long tails.
If you have lost the original instruction manual that came with your Brother sewing machine, you can download one for free at the Brother website.
Jul 12, 2011 | Brother XL-5130 Mechanical Sewing Machine
When I raise the lever the presser foot only lifts a bit at the end of the motion and doesn't stay up. Is the foot supposed to remain up after the lever is raised? In the first 40 degrees of motion...
yes, pressure foot lever should stay raised, this sounds like the spring has broken in your machine. if you are comfortable with delving into the machine you could open it up and take a look. alternatively take it to a sewing repair man and get it serviced as well as clean and lube.
Jun 26, 2011 | Kenmore 15218 Mechanical Sewing Machine
I cant get the needle to catch the bobbin thread. I just received the machine, i might not be doing it write? any suggestions
This has to be done by hand.
Raise the presser foot, then thread all the way down to the needle. Put in the full bobbin with thread end loose and visible. Hold the end of the thread in the needle with one hand and carefully turn the wheel so that the needle lowers and lifts the bobbin thread. Place both threads behind the presser foot. Now you can sew.
Jan 24, 2011 | Brother XL3750 Mechanical Sewing Machine
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
I have forgotten how to thread it
Hello :
Here I'll tell you how to thread a sewing machine . Just let me know if that worked or not to provide another help .
  1. Raise the needle to its highest position by turning the handwheel toward you.
  2. Raise the presser foot. This will allow the thread to easily pass through the threading points and will prevent the machine needle from becoming unthreaded when you begin to stitch.
  3. Place a spool of thread on the spool pin located at the top of your sewing machine. If the spool pin runs horizontally, secure the spool of thread with the cap provided.
  4. Take hold of the thread end and pass it through the designated threading points on the top of the machine casing, then down toward the tension assembly. The tension assembly is located on the left side of the machine and controls the flow of thread.
  5. Take the thread under the tension assembly and back up through the next threading point at the top left of the machine. Make sure the thread has passed between two tension discs as well as the hook that may be attached to the left side of the tension dial.
  6. Push the thread end through the lever at the top left of the machine, if applicable, and down through the threading points at bottom left and above the needle.
  7. Thread the needle from the front or back of the needle. The threading direction will depend on your machine type.
  8. Pull a few inches of thread through the eye of the needle and pull the thread to your left.
  9. Insert a wound bobbin into the machine, if necessary, and close the throat plate. A few inches of bobbin thread should be pulled out to the right and sticking out from under the closed throat plate.
  10. Take hold of the thread that has been threaded through the machine needle.
  11. Rotate the hand wheel toward you until the needle disappears into the bobbin case.
  12. Keep holding on to the thread and move the hand wheel so the needle is once again at its highest position. As the needle rises, a loop of bobbin thread will come up as well.
  13. Pull the thread out toward your left to draw the bobbin thread loop further out of the bobbin case.
  14. Let the top thread go and pull the bobbin thread up until the end comes up. Pull the top and bottom threads under the presser foot and to the back and right of the machine.
Things You'll Need:
  • Spool Of Threads
  • Threaded Sewing Bobbins
  • Sewing Machine Needles
I hope that will help .
Don't forget to rate if that was useful please !
Apr 05, 2010 | Sewing Machines
Hd-110 can't pull up the bobbin thread
If the needle will not catch the bobbin thread, try replacing the needle and make sure the flat side of the needle shaft is facing the back of the machine.
Always thread a sewing machine with the presser foot up.
Lower and raise the threaded needle, while holding onto the end of the thread. This will pull up the bobbin thread.
Take both thread ends under the presser foot and to the back of the sewing machine.
Hand Walk the needle a couple of stitches before using the power pedal.
Mar 19, 2010 | Singer HD-110 Mechanical Sewing Machine
Bobbin
have good eye hand cordination and lick the end of a perfectly cut thread up to the bob make sure not too have any loose thread on the end or will not go threw
my mother when i was little taught me to sow on and old 32 singer up her new 65 singer when she bought it used i never could use the stick to sow
or you can cut a piece of fishing line little fast acting glue to the ends together or grease thick sowing grease this will keep fish line and thread together as your putting in bobbin
fishing line about 1/2 foot piece
May 16, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
67 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
