Question about Dryers
Hoover nextra 7 tumble dryer hnv172 instrucvtion manual
5 Suggested Answers
yalmer
  • 549 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
SOURCE: I have a hoover Nextra
My nextra has just started to do same thing, does anyone know what is wrong
Posted on Jun 11, 2008
vickygomar
  • 460 Answers
SOURCE: Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
Posted on May 15, 2009
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
Hoover nextra tumble dryer
the tab is broken, try stuffing a folded piece of paper between the button and the body to stop it coming back up and be using the mains to switch it on/off.
Aug 18, 2013 | Washing Machines
User manual for hoover nextra tumble dryer
I have a Hoover Nextra washer/dryer machine. It has been working fine but 2 days ago it stopped taking water into the drum. When I put the machine on, I can hear water running into it and the water does go into the powder compartment and clears that. However, only a tiny bit of water is getting into the drum of the machine.
In case it is relevant, there is only one hose at the back, not 2 hoses like some machines have. I don't think it can be water pressure as it has always worked before.
I hope someone can maybe give an idea as to how to fix it as I have toddlers and need it fixed asap. Is there anyway we could fix it rather than have to call out a service engineer. If there is something we can try can you answer in simple language as we don't know much about washing machines.
Thanks very much
Dec 21, 2010 | Dryers
Tumble dryer doesn't dry. It tumbles but there is no heat
Either your heating element went out or your thermostat (which regulates the temp).
Jan 29, 2010 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
thank you
May 14, 2009 | Dryers
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Dryers Logo
226 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
