Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Sim card invlid on switching,How to remove the lock,
    President:
  • 1,010 Answers
If your phone displays the 'Invalid simcard' then your phone is currently locked to particular network. You need to unlock to use it with other network.
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website http://www.unlock-zone.com/ which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Posted on Oct 07, 2010
How do I activate my new phone?
It's the same throughout all brands.... Remove battery cover or any cover holding sim card and/or SD card.
Locate the position the sim card is placed and insert it correctly. Do the same with the SD card if you have one. Put the device back together then switch on. The phone will check your sim card and connect to your network provider (if phone is unlocked to all networks) you will find out quick enough if the phone is locked to another provider, it won't work !
Assuming it pairs with your network, the on-screen instructions will tell you how to proceed, like any email accounts etc that you want synchronised with your device. It should automatically load your previous contacts and will install some updates automatically too.
These are generic instructions for the average type phone, read any manual you have carefully. but this is the general way..... good luck.
One more thing....make sure the device is charged.
Jan 05, 2015 | Cell Phones
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
Jul 11, 2014 | Casio G-zone Commando
Invlid sim
If your Nokia N93 says Invalid Sim it's locked to network...You need to unlock it from network lock to use with other GSM Network sim card....Find the network,Country it's locked now,get the Unlock code at
Mobileunlocksolutions.com/nokia-n93/rs1wp9/ and Unlock it from network lock easily...
Sep 24, 2012 | Nokia N93 Cellular Phone
How to change a sim card in an iphon 3gs
to remove the sim card this requires a very small tool or fine needle or fine piece of rigid wire and insert it into the ejection hole located near the sim card.
Hope this helps
Aug 21, 2012 | Apple iPhone 3GS Black (16 GB)
The unlock switch wont work so i can look at anything of my nokia nuron
First switch off the phone then remove battery and sim card and memory card. then turn on the phone without this. try to lock.if it again unables to lock then insert the sim card, memory card and battery.
May 04, 2011 | Nokia 5230 Cell Phone
Asphalt2 unlocking code for samsung d780
1 - Switch ON your Samsung D780 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung D780 is locked to.
CODE: Its the unique Unlock Code for your Samsung D780.
If it does not work, you can try these methods:
Method 1:
2 - Samsung D780 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung D780 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung D780.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung D780.
Kindly rate and revert
Jul 12, 2010 | Samsung D780 Cellular Phone
How do I get the sim card out of a 3100 nokia
1.remove the back panel
2.remove battery
3.remove sim lock
by this you can remove your sim out from your phone.
*but switch off your phone before removing your battery.
Dec 15, 2008 | Nokia 6010
How to unlock samsung SGH-A411
If it's the phone lock (not the SIM) you can try this:
Switch off phone, remove cover, battery and SIM card.
Replace the battery and switch on phone.
When phone ask for SIM card enter the following code -
*2767*3855#
Note this will clear the phone memory so you may lose a few things.
Next switch off and replace the SIM card, battery and cover.
Hope fully this will work.
Jul 08, 2008 | Samsung SGH-R225m Phone
Forgot lock code nokia n73
i lost my lock code how to clear it
Mar 27, 2008 | Nokia N73 Cellular Phone
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
401 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
