Canon PIXMA MP470 Scanner Laptop Bluetooth Connection Problem
  • 4 more comments
  • Akilan May 29, 2008
    I am not able to scan the document please helpme
  • swhite_guy Jul 18, 2008
    canon mp470 won't scan. Instead window comes up for publisher but them nada.
  • toibelu Oct 12, 2008
    bought this thing thinking it had bluetooth, like it said online and on the box. then forked over $20 for the required adapter. installed. now i go to scan and it says "connect usb cable and turn on the PC." i am really upset. i'll be writing to canon and canelling my order of a canon rebel camera i was buying.
  • mosswoodball Oct 12, 2008
    I also bought the bluetooth adapter but when I wanted to scan a photo, it said I needed to connect a USB cable.
  • wmmazur Nov 23, 2008
    Same thing - Pixma 460 bluetooth receives print requests ok but not scans. I even tried updating the driver.
  • Anonymous Jan 20, 2009
    same problem
5 Suggested Answers
SOURCE: canon pixma mp470 printer error
canon pixma mp470 printer error u051
Posted on Oct 18, 2008
SOURCE: My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Posted on Jul 30, 2009
  • 672 Answers
SOURCE: I have Canon Pixma mp470 won't scan to my computer
I also have a mp470. Try this before the driver download. Click Start, click all programs, select Canon utilities, select mp navigator, click on mp navigator again. On my pc this opens a window where I can select Scan/import from the platen or from a memory card. If this does not work here is a link to Canon to get your drivers. Note: turn off and uninstall your MP470 before installing the new drivers. Select your operating system from the list and select your desired drivers.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15403
Posted on Feb 11, 2010
pineworks
  • 4041 Answers
SOURCE: Canon pixma mp470 won't print, jamming paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 03, 2010
Canon MP470 prints colors light on Mountain Lion
So go back to former driver since this one does not work. A no brainer!!!!!
Aug 28, 2017 | Canon PIXMA MP470 All-in-One Printer
I can't get the scan function on my canon mp470 to work. It says the drivers for the scanner aren't installed. I have reinstalled the software directly from the manufacturer at least 5 times. It...
Go to Control panel = Uninstall program = remove Canon Mp470 driver... after completing = re-install the programme again.. while installing program you must select "Easy install" thanks...
Aug 27, 2011 | Canon PIXMA MP470 All-in-One Printer
I have my printer connected to a Toshiba laptop running Windows Vista. my scanner is a Canon MP470 and I don't have the manual. can you tell me how to scan with this printer.
To scan an image in Windows Vista, do the following:
Go to Start > All Programs > Windows photo Gallery > Select the File Tab and select Import from Camera or Scanner.
It's a bit slow starting...but it will scan for you.
If you are still experiencing problems then download the latest drivers from canon here for your printer/scanner:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp470#DriversAndSoftware
Feb 28, 2011 | Canon PIXMA MP470 All-in-One Printer
Feb 11, 2010 | Office Equipment & Supplies
Scanner does not work
Try uninstalling the scanner driver. Then unplug the scanner. Reinstall the scanner driver on the computer and then plug the scanner back in (USB connection).
Jul 30, 2009 | Canon PIXMA MP470 All-in-One Printer
Lost disk for printer mp470
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq14
Jun 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner unresponsive
Aug 10, 2008 | Canon PIXMA MP470 All-in-One Printer
532 people viewed this question
k24674
jasbo
jasbo
