Question about Kenwood VR-705 Receiver
I just bought the VR-705-SA (same as the 705 except with component video out) and there is no sound coming out this receiver what so ever. It powers on alright but it does not show any of the surround sound speakers, and there is no sound from it anyway. I am not using the video outs at all (tried it) but I have all three digital inputs and two analog inputs in use and nothing is working. I already tried the reboot suggested by the manual but it refuses to send out any sound. Please help me.
tech48
  • 624 Answers
SOURCE: receiver works with digital signal input jack only.
Are you talking about the 6 channel input with all RCA jacks? Please explain a little better, it is very hard to know how you have it connected without a very good description since I can not put my eyes on it. You may need to check the settings, it may have the rears muted. More information from you will help me to be able to help you.
Posted on Feb 06, 2009
SOURCE: Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Posted on Feb 09, 2009
  • 63 Answers
SOURCE: Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Posted on Mar 16, 2009
  • 4 Answers
SOURCE: I have a vr-405 5.1 channels reciever, I have it
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Posted on Mar 17, 2009
shahabdun
  • 249 Answers
SOURCE: optical input not working
Was it plugged in the right places?
Posted on Jul 06, 2009
How to reset the Kenwood vr-716
Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
Nov 13, 2016 | Kenwood Audio Players & Recorders
I just bought a Panasonic plasma tv model TCP50S2 and I can't seem to get my Kenwood receiver to work with it. Do I need to set the remote to the Panasonic tc? If so does anyon know the code number? I...
I assume you want the TV sound through the receiver?
You need to connect the TV digital out to the receivers digtal in.
This is probably an optical connection.
Then you need to switch the receiver to the correct input. You may also need to tell the receiver what kind of connection is made: Optical or coaxial, if it doesn't detect this automaticly.
Sep 22, 2010 | Kenwood VR-705 Receiver
Connect a Sony SA-W3800 powered subwoofer to a kenwood receiver
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
Jul 02, 2010 | Kenwood VR-309
How do I connect my Sony PS3 with HDMI and component sound with Kenwood VR-606
Component outputs do not provide sound. Component CABLES however can be used as a rather equal alternative to analog cables for audio.
Your receiver does not have connections for component, nor HDMI. You can however still connect your PS3 to it for audio by any one of its three digital inputs. It only has S-video and does not upconvert video signals so I recommend against making any video connections to it. Connect the PS3 video directly to your television for whichever video input it is compatible with High definition video. This method will always provide the best picture.
Dec 12, 2009 | Kenwood VR-606 Receiver
Optical input not working
Jul 06, 2009 | Kenwood VR-705 Receiver
Connection problems
If the CD player has left and right outputs and the receiver has those inputs for a CD or DVD then there's a start.
Speakers...match them up to positive and negative with no power to either component.
Jun 09, 2009 | Kenwood VR-307 Receiver
Wont Power On..
I had the same problem. It's a voltage regulator (maybe 7812 or 7912) problem. In my case the problem was cracked soldering joints on the little PCB where the IC was soldered. Try this: open the case; on the sides of the big heatsink are attacched 2 IC Voltage Regulators. Check these ones for properly solder. After that I can power up my amp without problems.
I have another problem: now my surround speaker and sub are very very low volume even at 100%. Can someone help me?
Feb 23, 2009 | Kenwood VR-705 Receiver
Onkyo 705
You have probably done this, but have you changed the video settings in the setup menu to have the tv using HDMI out? I believe it is under the first option when the menu comes up.
Dec 23, 2007 | Onkyo TX-SR803 Receiver
Kenwood VR-705 Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
