Question about Sansui Audio Players & Recorders
I HAVE SANSUI AU517AMP AND I HAVE REPLACE ALL 4 TRANSISTORS 2 IN EVERY CHANEL.I MUST DO ADJASTMENTS? (2SC1403A 2SA745A WITH MJ15024 MJ15025
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: TRANSISTORS
Find a music store that sells yamaha keys and PA gear. Ask them for help. Couldnt cost more than $10 for a good schematic
Posted on Jan 11, 2009
A sansui tv switches on and off by itself. What could the problem?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Desolder out the horizontal output transistor, and now power on the set. If the set now powers ON, replace the horizontal output transistor. It is faulty. [Collector to emitter or collector to base leak]
Jun 26, 2015 | Sansui Televison & Video
I have a crown xls602 with no audio. Speaker and power relays activates normally, signal leds palpitates with input but no sound. Appreciate any help. Thank ou.
- Use your favourite search engine (Webcrawler is dandy) and type your question/info into it.
- SEARCH ENGINES ARE YOUR FRIEND!!! Type in keywords and check the results.
- I'm not an expert but it almost sounds like maybe a speaker relay or whatever on the amp has bailed out.
Good Luck :)
R
Feb 13, 2015 | Crown XLS 602 2-Channel Amplifier
One side dead
hi zm_16dec,
Right chanel fully dead , output transistor burnedout ,
Without knowing the make and model of your amplifier
all i can advise is to replace the unknown part number of
the transistor.
Look for the working left channel output transistors and
replace the bad transistors in "pair". These may include
other components but check on it as well.
Check the speaker system, especially where that channel
is connected.Inspect speaker wires or cable up to the speaker
itself.
Amplifier wont blow without reason.It could be from the wirings,
speaker or volume settings of the unit.
Thanks for choosing Fixya for assistance!
Dec 24, 2012 | Audio Players & Recorders
Sansui sv29276
Replace all the capacitors connected to the horizontal output section. Especially capacitors connected to the collector of the horizontal output transistor.
Oct 16, 2012 | Sansui Televison & Video
One of my outputs does not work at all, the other works fine, when i go to bridge it doesnt word even not. How can i find out what issue i must repair, can it be the Si-PNP 250v 16a 250w
hi,
First of all you have to check The positive and negative 95V in the collector pin of all output tansistors. There should be +95V in the all collectors of MJ15024 and --95V in all collectors of MJ15025 poer the output transistors of faulty channel.ANd tere should be +/-- 0.5 volt in all output transistors base pin. All emitter pin should be aproximatly 0V. If not then you have to check the tansistors Q13 to Q16 and Q17 to Q20. Also the driver transistors Q9, Q10, Q11,Q12,.
If you need the schematic diagram that i will sent it to you.
ok
Jul 31, 2011 | Crown XLS 602 2-Channel Amplifier
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
TRANSISTORS
Jan 10, 2009 | Audio Players & Recorders
Faulty line stage sv2918 sansui tv
Can you please post the make and model. That would help u sto provide you with more details.
Thanks,
Dan
Dec 01, 2008 | Televison & Video
Amp : sansui au11000 blown transistors on driver board
may i ask you did you put silicone grease in your transistor and apply a good mica insulator in all of your transistor---------look for any burnt resistor or explosive capacitor -----check for scew tie your supply voltage to earth by wrong.
Aug 03, 2008 | NAD C320 2-Channel Amplifier
19 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
