Question about HP Compaq Presario SR2150NX PC Desktop
Running XP PRO SP2
Dray,
The reference you gave was to HP's page for firmware, etc., but it is labelled as Vista. HP chooses not to recognize XP when you go from pre-installed Vista to XP, and does their best to help, but with a lecture on upgrading to XP. Will the updates on their Vista page work under XP ?
Thanks,
DC4580
  • DC4580 May 29, 2008
    Much appreciated. Thanks Chris.
    DC4580
  • DC4580 Jun 07, 2008
    Here is the solution:
    I was on with HP tech in chat and she was close, but on wrong device. Here is the procedure that corrected my problem:
    _____________________________________________
    Goto Control Panel->System->Hardware->Device Manager.
    Click on View, choose devices by connection.
    Expand the ATI IDE Controller
    Expand the Primary IDE Channel
    Make sure ATAPI DVD A DH16AYH is listed under the expanded IDE Controller.
    Double Click the Primary IDE Channel
    Click on Advanced Settings Tab
    Change the transfer mode for Device 0 from "DMA if available" to "PIO only"
    Click OK
    I am back to normal use of the Cd drive now. Thanks for any assistance.
  • 77 Answers
They may be hit or miss using the Vista drivers for XP. I'll check around the web to see if they have any XP drivers for you, and post them back up.
Chris
Posted on May 29, 2008
I just got a Pro 205 printer . The software that came with it microsoft dosn't recognize so I need one that microsft will recognize. Thank you. arrow13@verizon.net
Hi. There are Microsoft drivers available for download in the Lexmark website. If your using Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by going to Start > right click on Computer > Properties. Then click on this link to the Lexmark website. http://bit.ly/9faEwK . On the bottom of the page, you'll see dropdowns for Microsoft, Macintosh and Linux/Unix operating system. For Vista, choose Microsoft Vista for 32-bit or Microsoft Vista X64 for 64-bit. For Windows 7, choose Windows 7 for 32-bit or Windows 7 X64 for 64-bit. Download the Driver but not the Firmware update. Hope this helps.
Mar 15, 2010 | Lexmark Office Equipment & Supplies
I unable to install Xp in my compaq cq61-132tu. The install option just doesn't get highlighted. Also, i don't have another computer.
I assume you are attempting a "downgrade" to Xp from Vista, since this laptop does not come with XP.
From the Compaq information page:
  1. HP does NOT support XP for consumer notebooks, so if you have any difficulties regarding XP, do not expect HP will help you.
  2. HP may demand you to install back VISTA if you have hardware problem to troubleshoot it.
    An option to consider-put your original Vista hdd away and install new one for XP.
  3. Some of the notebook features may not work in XP due to uncertified licenses pointed in this guide.
  4. Microsoft has released three (3) Service Packs for XP, use only SP2 for the first trial. Why? Since many of XP drivers are released based on XP-SP2.
  5. Always make Vista Recovery cd/dvd before downgrade to XP. see it here
  6. You have a folder with drivers & programs that may prove very helpful after XP downgrade.
    Copy folder C:\Swsetup to DVD Before formatting your hdd.
  7. If you have a pre-SP2 XP cd, get the full SP to Integrate with Nlite: SP2 Nlite HERE
The help guide for downgrading is here. There is a lot of information on this process written there.
However, if what you want is a an XP look and feel so you can compute the way you used to, change the Vista to look like XP in the display properties.
If you are trying to run non-Vista software, try running it in compatibility mode. To do this, right click on the program files and select properties and then locate compatibility..
Jan 04, 2010 | HP Presario CQ60-204NR PC Notebook
Want to install xp instead of vista - but end up in caldera dr dos
Alot of the reason is because they don't want you to down grade from Vista to XP. But see if this helps. Start your pc, insert XP disk, as soon as the screen comes up press f12 which will allow you to choose the booting sequence, click CD- ROM and the disk should start to be read. understand this tho by downgrading you will have a hard time finding the appropiate drivers for most of your devises since they were meant to be runned by Vista. Here's a tip go find the drivers in europe (be it toshiba.europe, Dell.europe) for they are still running XP. to find the drivers for your particu;ar pc just find the series number and the last unit to run with xp and viola a working xp on a vista pc. Hope this helped
Good Luck =)
May 30, 2009 | Microsoft Windows XP Professional SP2
Compaq presario CQ40-330 TU notebook drivers for win xp sp2
download from www.hp.com click tab support & drivers type model first follow next instructions.
May 29, 2009 | Computers & Internet
Replacing window vista with xp pro sp2
hello,to install xp pro, you will need to uninstall vista by formatting your hard disk
May 01, 2009 | Computers & Internet
Can't use VPC-CG9 as PC camera.
I don't know why this wouldn't work on Vista HP, but this excerpt from the manual suggests that your XP SP1 Pro would not work without the SP2 rollup:
"Please perform the following upgrades before connecting the camera to a computer.
-Upgrade Windows XP to SP2.
Install Windows XP SP2.
-Install Windows Messenger 5.0 or later version.
Download Windows Messenger 5.0 or later version, and install it.
-If using MSN Messenger, please install MSN Messenger 7.0 or later
version."
Perhaps if you are following the steps exactly in the manual and it still does not work, upgrading Messenger will magically help.
Mar 24, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
Using XP sp2, excel 2000 and HP 4250 printer. Any
The print settings can be different for different programs. Open Excel and in the File menu, choose Page Setup. Click on Options, and towards the bottom is a setting that says Copies. Change this to "1" and hit OK, and you should be fine.
Hope that helps!
Mar 09, 2009 | HP LaserJet 4250n Printer
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Creative Zen - can't download music from XP SP2
When you plug the Mp3 player into 2 computers running slightly different versions of XP, a reformatting occurs which will cause it not to work on one PC or the other. You must reformat your player for the home computer. Actually, you might want to check the firmware also: Go to Creative's website and double-check the firmware - it will also give you the best way to reformat your player:
http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players
Jul 06, 2008 | Creative Labs Zen Digital Media Player
Drivers not found.
Your Compaq came with Vista installed. Finding drivers for XP Pro with SP2 seem to be very troublesome. Somewhere HP Compaq has these drivers for you laptop. If you call them & they find out you bought XP Pro they will not support you in finding the proper drivers for XP Pro. How ever you can call & ask what it will cost for a recovery CD for XP Pro w/SP2.
Click the link to Compaq & listed is your laptop & what software & drivers are listed. If you need other drivers that are not listed, post what you want I'll try & find them for you. Please be as detailed as possible.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3641194&lang=en
You may find some here.
http://search.hp.com/query.html?sh=1&charset=UTF-8&la=en&qt=drivers%20for%20XP%20A902TU%20Notebook
Feb 19, 2008 | Computers & Internet
HP Compaq Presario SR2150NX PC Desktop Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
