Question about Ashly Xr2001 Stereo 3WayMono 45Way Xover
I would like to instal 15v DEXA regulators in my XR2001? Do you think it will be a soud improvement? Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Any low impedance power supply will likely result in better sound. However, you should expect any improvements to be marginal at this signal level.
Posted on Oct 07, 2010
Clip light on
Does all the "Clip" lights are on? or just certain channel? if all "Clip" lights are on you have to check the +15V and -15V at Operational amplifier ic that is a 8-pin integrated circuit, pin 4 should have the -15V and Pin 8 should have the +15V, if just one channel shows the light constant on then its an opamp in that particular channel, let me know further to improve help.
Oct 24, 2013 | Peavey PV8 Mixer
Mixing board had all the lights come on at once and no sound
Despite the mixer's namebrand i can say that should be a low voltage supply issue, mixers have normally just 3 voltages, and the ones with effects 4, the critical voltages that mantain a mixing board working are just 2, +15V and -15V and you can check for them at Pin4 for -15V and pin8 for +15v of operational ic's at any channel with the mixer on, one of those are not present and this is you issue for sure, certain mixers have fuses for this two voltages but since you are not posting the namebrand i can't figure it out, if one voltage is missing could be the fuse or the power regulator that reads"MC7825" or "MC7915" which 7815 is for the positive rail and 7915 for the negative one, both are located in the power supply board, let me know more to help you more.
Oct 05, 2013 | Music
Problems
This may be an issue with your power supply regulation, check opamp's ic's for +15V at pin-8 and -15V at pin-4, this may help to troubleshoot the issue.
Jul 03, 2013 | Peavey PV6 Mixer
Peavey renown 212
If no fuses blown you probably have an issue on your +15V and -15V power supply regulators, this can be tested by checking opamps supply voltage which should be +15V at pin-8 and -15V at pin-4, let me know further.
Jun 22, 2013 | Peavey Music
Peavey Problems
Check speaker impedance or disconnect speaker leads, then use a 9V battery to verify cone movement and if this test is ok, then go inside the amp, if there's no fuses blown check opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, let me know your results to help improvement.
May 21, 2013 | Peavey Electronics Peavey Max 112 Bass...
The signal lights all flash on and off and the unit will not power up..
This is a common issue with peavey mixers and generally speaking could be addressed by checking the opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, this should help to troubleshoot the issue, let me know to help improvement.
Oct 19, 2012 | Peavey Electronics Peavey PV14 Mixer
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
G1x zoom guitar effects no power even using an adaptor
if you're using an adaptor other than the original zoom, make sure it's 300mA or more and try switching the polarity.
Jun 20, 2011 | Samson ZOOM G1x Guitar Effects Pedal
All the clip lights come on when connected to mains power
Power supply +15V and -15V failure, pay special attention to regulators.
Apr 08, 2011 | Peavey PV8 Mixer
Ashly Xr2001 Stereo 3WayMono 45Way Xover Logo
49 people viewed this question
Top Ashly Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Ashly Music Expert? Answer questions, earn points and help others
