Question about Sony Ericsson W200i Cellular Phone
Unable to send SMS
I altered the service center no. now i am not able to place + sign for the international code (i can only write digits 0123....) hence the service not working please help me out
    Brigadier General:
  • 3,614 Answers
Press the 0 (Zero) & hold it for 3 sec. until the +sign came out...
Thank you
Posted on May 29, 2008
1997 dodge stratus stalls while driving. Check engine & oil light on. Putting out sensor codes- P0123 & P040. Some times it restarts while coasting or we sit for a while then it may start.
code p 0123 has several references
throttle position (TP) sensor A/accelerator pedal position (APP) sensor A--high input ===causes wiring short to positive -- TP/APP sensor or switch --ECM
also refers to TP/APP --low input==causes wiring short to ground ---TP/APP switch---ECM
with code P040 , I feel that you are missing the last digit or letter
code p0400 > p 0409 all refer to EGR system problems and p 040A >F again refer to EGR system problems
take it to an accredited service center with experience on your make of car and have it properly diagnosed
Dec 05, 2016 | 1997 Dodge Stratus
Accenture alarm
Default code for ade accenta panels is 0123
Feb 07, 2014 | Home Security
Code for sharp tv
Hello
Three ditgit universal remote codes for Sharp TV with GE remote are:
591, 604, 729, 671, 679, 684, 809
Four digit codes are:
0079 0123 0063 0020 0004
.............0009 0226 0266 0006 0095 0122
Dec 20, 2011 | Universal Remote Control GE174Universal...
Radio code for 2001 chevy blazer
1) Press the 2 & 3 numbers on your radio at the same time for about 10 seconds; a 3 digit code will come up 2) Press the am/fm button for about 10 seconds; another code will appear 3) Write those numbers down in that order 4) Dial 1-800-537-5140 and enter 202107 followed by the * sign 5) Enter the 6 digit code from your radio followed by an * 6) The phone number will give you a 3 or 4 digit override code, enter this code into your radio just as your owners manual tells you to NOTE, if the code you get back starts with a 0, drop the zero from the code. So if you get 0123, your code would be 123. Hope this helps out a lot of people and screws the dealers!
Oct 23, 2011 | Cars & Trucks
My dell, latitude d630 gives error 0123 on diagnostic and beeps. how do i solve this?
Remove and reinstall the memory for the error codes: 1000-0122
1000-0123
2000-0123
Please see the Service manual for instructions on how to remove and replace the memory.
Aug 06, 2011 | Dell Studio XPS 1640 Notebook
What is the code of sharp tv model 2V-FW75M
Hello
You are asking about the universal remote code for Sharp I assumes, and place this solution before you.
Three digit universal remote codes for Sharp are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 16, 2011 | Sharp Televison & Video
What to do if there is corrosion due to water in Internal circuit
The corrosion in the Internal Circuit may need replacement to get it work. This can be done at the Sony Authorized/Factory service center. It is better to replace the internal circuitry for complete resolution, better to contact the service center to check if it requires replacement.
Aug 06, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Phone request me to enter the sim code when i used Cambodia's SIM
not sure if this works with the 2008 but its something you can try, i put a sim card in my LX and was asking for a special code to unlock the phone, well right now tmobile isn't unlocking the sidekick, but you can trick the phone into using the sim card. First go to your settings, go to "SIM Center" and click on disable sim lock, enter in whatever your sim password is (if you dont know your sim password get your PUK (pin unblocking key) number which customer service will give you if you call 611, you can change that SIM pin by typing **05*PUKnumber*newpin*newpin#) now if you wanted to change it to "0123" if your puk was 9483992 its 7-9 digits you would type **05*9483992*0123*0123# now your sim pin is 0123. (trying not to make this super complicated) it will say sim pin not accepted click ok, now click change sim pin you can type the same sim pin 3 times if you want, 0123 0123 0123 now at the top of the screen bars will show up with a white phone beside it, go to Settings-Network Options-Scan and Select Manually, the SIM network should come up, click ok when it finds it and it will connect, now you can call and text on whatever sim you have in the phone
Mar 04, 2009 | T-Mobile Sidekick
Kenwood kdc-3022
the only way you can get the code is to ring kenwood with the make and model or try 0123 ,1234,0000,4321
Jul 29, 2008 | Kenwood KDC-3022 CD Player
Unable to send sms on my sony ericsson W200i handset
take the phone or call your mobile providers to better assist you or do a master clear of the settings on the phone.
May 29, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
59 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
