Question about Canon i850 InkJet Photo Printer
Streaks in printing
When I print especially in black, the lines are streaky. I tried cleaning and it still prints in streaks. What do I do?
  • Anonymous Jul 07, 2008
    Same thing, except if I print in high quality, the results are acceptable whereas before, standard printing was great. Now standard streaks like crazy.
    Master:
    Sergeant:
  • 461 Answers
YOu might want to perform some cleaning or reinstall of ink again... you might find below details useful..
http://etech.maiila.com/?p=46
Posted on Jun 05, 2008
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
Streaky lines through photographs when printing
remove the ink cartrages and clean the connections and print heads with rubbing alcohol on a qtip. this will be messy. let dry for a few minutes and reinstall the cartridges. also streaks can be caused by low ink.
Mar 07, 2011 | Brother MFC 210C All-In-One InkJet Printer
White streaks showing in columns of black printing but colors are fine. Black cartridge has been replaced but streaky black printing is still a problem.
If your printer prints like thisslamfix_24.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Dec 22, 2010 | Samsung CLP 300 Laser Printer
The left hand side of each page prints some streaky dark lines. I've tried to clean it and put it in cleaning mode but nothing works. Help please!
Remove the toner cartridge. Turn it over and slide open the gate that covers the drum. Do you see streaks on one end of the little colored cylinder? (drum)
If so then the streaks are coming from the cartridge.
90% or better of the time, especially on HP's the print quality issues are coming from the cartridge.
Good Luck and Thank You for using Fixya.
May 13, 2010 | HP LaserJet CP1515n Printer
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Printhead problems Canon PIXMA MP780
that definitly sounds like it needs to be replace, have you tried using the printhead cleaning utility?
Dec 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Streaky Copies
It dose not have a print head. But it dose have a drum. Are the streaks thin lines? Also, is only part of the copies fixed into the paper ( can you rub part of the copies OFF)? If you can rub off part of the copies - your problem is in the fixing unit. If the lines are fixed and can not be rubbed OFF you most likly need a new drum unit. Good Luck... Either way you will need a service rep. out to fix your problem
Oct 07, 2008 | Canon imageRUNNER 2200
Streaky print out from canon Pixma mp830 all in one
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Dec 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon i850 InkJet Photo Printer Logo
141 people viewed this question
old marine
old marine
