Question about Canon iRC3100 Printer
Hi I have an error E000067-0100 on my canon IR 3100C. I have checked the various messages here and people explain that it could be the drum / sensors..... I am prepared to tamper with the machine and to clean the sensors etc, but I have no clue where the sensors are and how to remove the drum itself. Can anyone explain that to me. I appreciate any help I can get. thanks
Canon ir 3100c error 000020-01a2
Hi this is Alex Walker i will be glad to assist you
call me +1(404)981-1535
Nov 19, 2015 | Canon Office Equipment & Supplies
E000012-0001 ir 3100c
this is error for motor of drum unit. It can be that he needs to be reconnected or replaved. In some cases the drum unit gears are broken and copier then reports error.
Call service!
Sep 10, 2011 | Office Equipment & Supplies
Error 200081 Canon iR 3100C EUR PS3
better to call your local dealer they knew it
May 31, 2011 | Canon iRC3100 Printer
Canon IR C3220N--error code E000020-01b0
If the drum units have been removed repeatedly without the drum guide service tool it's possible to break one or both tabs .These tabs open the toner hopper when the drum unit is slid in, and if they are broken, toner will not be fed into the drum unit.
NOTE: The unit may work for a while until the developer to toner ratio drops enough to cause an error.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Canon imageRUNNER C3200 Color Printer
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Canon IR C3200--error code E000020-01b0 explain this code please
Hi there
Error code E000020-01B0
That code relates to the yellow drum unit.
The unit was probably damaged taking it in an out.
Needs to be replaced.
Or try.
1. Information UPDATE UPDATE - the Drum units are as follows:
Yellow - 746
magenta - 215
Cyan - 758
Black - 9
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 04, 2010 | Canon imageRUNNER C3200 Color Printer
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon iRC3100 Printer Logo
539 people viewed this question
old marine
old marine
