Question about Stoves Ovens
I have a Stoves SN60FP Single Oven. Every time I try to use it, it cuts out after 20mins approx. and the digital display goes off as well. It does come back eventually, with the clock flashing. What could be the problem?
  • 116 Answers
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
If the oven was working before then
1. Power is gone from the unit - loose connector or neutral wire ( or ground wire depending on wiring system being used)
2. The power supply transformer (or transistor) on control board is busted. This is especially true if there was power problems in the apartment- power going on and off frequently. Check the wiring and see what comes up. Hope that helps
Regards
Posted on Sep 04, 2008
SOURCE: Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Posted on Jan 07, 2009
localwonder
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
SOURCE: need to adjust clock setting
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Posted on Nov 19, 2010
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Constantly cutting out and re-igniting the oven
air pressure switch broken oven thinks the fan is not working and turns it self off.
Oct 11, 2009 | Stoves Premier 600GRa Gas Single Oven
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Stoves Gas Oven
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
168 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
