Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wml540 wont pump out. All four error lights flashing
Water pump is broken
Posted on Feb 18, 2011
Instructions hotpoint wml540
Check belt hasn't snapped/ come off,,,then check motor action,,,,put on spin and tap motor gently see if it helps
Jun 16, 2013 | Washing Machines
I have a Hotpoint WML540 Aquarius which has stopped mid cycle, all the lights are flashing and it is stuck on 'pump out' can anyone please advise how to fix this?
Switch off the machine for sometime and then power it while holding the play/pause button. If the machine does not reset but continues to flash it is possible that there are errors within or is a failure of the panel. Check the door switch, check the connectors and finally check for moisture in panel- If so use a hair dryer to mop up the moisture by heating the panel slowly,
Jan 14, 2013 | Washing Machines
Hotpoint WML540 gets to spin then stops wont empty and all lights start flashing
hi sharon, i had simular problem, if your waste outlet from your machine to kitchen sink is pushed on to sink waste sometimes held with jubilee clip, disconnect it and check weather its clear cos it can get build up of ****** and stop water from draining, hope this helps.
Jul 08, 2012 | Hotpoint Washing Machines
My Hotpoint WML540 door lock light flashes and clicks 3 or 4 times then wont do anything? Is it a fault with the lock (which looks easy to replace) or something more serious?
First try unplugging the washer machine for about fifteen minutes or so. Then plug it back in. If the problem still there, then it is the board. It can be fix.
May 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint WML540 wont start wash cycle. The door lock clicks 4 or 5 times then the red door lock light flashes.
This sound like the main control board has blown and this is due to the motor shorting out, if you isolate the power supply and remove the control panel you will be able to remove the pcb/module and inspect it for signs of burning or split tracks if you find this is the case usually it is cheaper to replace the machine than purchase a pcb and motor.
Regards
Ian
Apr 20, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius WML540, HAS JUST STOPED WORKING ITS ONLY OVER 1 YEAR OLD,WILL START ANY WASH BUT JUST STOPS WHEN IT REACHES THE SPIN AND DRAIN AND ALL LIGHTS START TO FLASH VERY FAST CAN YOU HELP.
Could be the pump blocked or not working, check the pump for blockages or wiring faults. For Hotpoint, Creda and Indesit error codes that include flashing lights visit selfix-uk
Mar 20, 2010 | Washing Machines
I have a Hotpoint Aquarius WML540 washing machine and after the wash and the rinses, all the lights start flashing and the programme will not go any further. I would like to know what is causing this and...
I would like to know what is causing this and how to solve it.
Sep 22, 2009 | Washing Machines
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
853 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
