Question about Cameras
A broken shutter curtain - Cameras
    Brigadier General:
  • 11,967 Answers
You don't say what camera you are using...I'm assuming an SLR since you are complaining of a broken shutter curtain. This is an expensive repair and can only be done by an authorized repair service recommended by the manufacturer.
Posted on Oct 07, 2010
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
I was loading film into my Nikon EM for the first time and it wouldn't work so I had to take it out, then I pressed the shutter and it closed and it didn't open back up so I played around with the shutter...
You can't touch the shutter curtain at all on any film camera and the cost of repairing that curtains far exceeds the cost/value of the camera. Sorry for the bad news but the only thing worth anything on the camera now is the lens.
Dec 10, 2010 | Nikon EM 35mm SLR Camera
I have a Nikon EM and was loading the film and trying to make it work but then all of a sudden the shutter closed and wouldn't open. So I played around with the shutter curtains and now they're broken and...
This question was or has been posted twice. As I said the shutter curtain damage will cost more to repair then the camera is worth and the only thing to save is the lens.
My Minolta Maxxum 400si film SLR seems to have a jammed shutter and the shutter curtains seem to be mis-aligned (this would be because of the previous owner, not me) but the bottom curtain actually seems...
With the shutter curtain out of place the camera will not function. If it is only out a little you may be able to persuade the shutter blades to fall back into position. If you bend them, or if they are out of the proper tracks then the camera will have to be sent to a repair service for repair.
Nov 23, 2009 | Minolta Maxxum 400si 35mm SLR Camera
I have a jammed shutter on my Minolta 400si SLR. It also has caught shutter curtains. I noticed this the moment I received it from an ebay seller. The shutter won't open beyond 1/4th of the way. No...
Touched the shutter curtains
Yes it will have an affect on your shooting. The curtains will not operate correclty if they are opening and closing at different speeds and / or not closing or opening completely. Your film will expose at different levels, and you will not get a correctly composed shot. You could try to coax the curtain back into place by GENTLY rubbing it with a Q-tip in the direction it is supposed to go. But those things are fragile and can be fickle. Your best bet is to take it to a shop.
Jun 20, 2009 | Nikon N65 35mm SLR Camera
Nikon 6006 shutter curtain
Shutter Curtain needs to be replaced.
There are 2 of them. Usually one goes out of position and brakes.
Mar 22, 2009 | Nikon N6006 35mm SLR Camera
Black area in photograph
Unless you are using high-end Nikon Speedlights with camera and flash set for Auto FP High-Speed Sync, your top flash sync shutter speed on the D80 is 1/200 second. The black band you are seeing at faster shutter speeds is because the second curtain of the shutter begins to close before the first curtain reaches the fully-open position (which is when the flash fires). The higher the shutter speed, the shorter the gap between first and second curtains. To get full exposure with flash, there must be an instant when the shutter is fully open -- first curtain completed travel, second curtain not started yet.
"As the speed increases the final image should get lighter" applies to ISO speed. Higher shutter speeds mean less light reaching the sensor, but that's not the cause of the black bands.
Mar 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Picture nearly all black
Lets see if the shutter curtains are opening properly : set to B and open the film back of the camera. Now release shutter and see if the first s. curtain has opened nicely and swiftly. Then release the second s. curtain and again see if you get proper closing of the curtain. If the shutter curtains ( usually just one misbehaves ) is slow to close then the shutter unit needs looking at . ( btw no point pouring liquids like benzine etc. into the shutter curtain are ... will make things worse ).
Sep 26, 2007 | Canon EOS Rebel G 35mm SLR Camera
Cameras Logo
106 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
