How to fix computer if it says "no signal"? - Computers & Internet
Check your monitor and that cables
Posted on Oct 07, 2010
My gateway computer power light blinks and moniter says no signal.turn it off held then power button on for 30 seconds.then turned it back on.same as before.
I don't think this has anything to do with the monitor since it is showing "no signal". this is an indication that the monitor is working.
Problem is from the connection between the computer and the monitor or from the computer itself.
Check the VGA cable and make sure it is firmly fixed into the computer and monitor.
Open the computer case, disconnect the keyboard, mouse, and every other thing apart from the VGA cord, then try again.
If there is still no signal, turn computer off again, remove it's power cord, then remove the system Ram, clean it and fix it back in. Then make sure the VGA card is well fixed into the mother board. After that, connect only he VGA cord and try again.
If non of the above seems to work, connect the computer to another monitor, and connect the monitor to another computer in other to confirm which is having a fault so that we can focus on it.
Keep me posted.
Good luck.
Jul 11, 2011 | Smart Modular SV3170A
HPW1907 monitor goes to sleep and says no input signal. Why? How do we fix this problem?
Hello.
Your monitor is not getting the input signal from your computer. Check to see if the cable from the monitor to your computer is snug.
Test this monitor on another computer, if possible, to see if your monitor or computer is the problem.
Hope these suggestions help.
Oct 23, 2010 | HP w1907 LCD Monitor
Monitor green light comes on then it says no imput
looks like there is problem with ur signal cable check that monitor signal cable is tightly fixed or contact ur product support center.
Mar 31, 2010 | HP Pavilion F1523 15" LCD Monitor
Injectors? 2.8 L cavalier has been wrecked, fixed and
if everything works then i would say yes, if there spark then replace computer, just check all your fuses and wiring to ijector,a noid light would be helpful,it plugs into injector plug and it flashes if injector is receiving a signal,there cheap buy one and test if its getting a signal first before replacing computer, if theres no signal(flashing) then replace computer but dont forgwt to check fuses.
Feb 23, 2010 | 1985 Chevrolet Chevy
The signal light is blink and cant get a signal from the wireless computer. Do i need to reset my router?
First off, the computer gets the signal from the router, not the other way around. Secondly, depending on the amount of walls, thickness of walls, amount of interference, the range on your router may not be far enough to reach your computer. If you used to get a signal and no longer can, unplug everything and plug it back in after a minute, that usually fixes the problem. If there is still no signal, try moving your computer closer to the router, or the router closer to the computer. If it is simply that the router does not have enough range, consider upgrading to a wireless n router.
good luck, let me know if you need more help
Dec 29, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Linksys wireless b router
Weak signal problem can be fixed by firmware update however, if the client computer is too far from the router, it can't be helped. What you need is a wireless range expander. What it does is give you another 100% signal or atleast stronger signal to the spot or area where you have a weak or dead signal.
Jun 29, 2009 | Linksys Wireless-G Broadband Router
My computer is stating no signal
Hey,
The monitor of the computer is not getting a signal from the computers video card.
this can be caused by a faulty video card, or just the computer not starting up properly.
instead of replaceing parts I would recommend you take the computer to a professional or someone knowledgeable in computers to get it fixed.
Let me know if you need anything else.
Thanks,
Ekse
Feb 20, 2009 | Targa Computers & Internet
Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Feb 02, 2008 | Balance CM2017 17" Monitor
No Signal?
Loss Of Signal - LOS Short for Loss Of Signal, LOS is generally an indicator on a networking device to ... has no connection on the other end, network is improperly configured
Good Luck, This should get your signal back again for ya.
Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Al2416WD LCD Monitor
No Signal problem
your lcd need a tech who could help you to repair the power failure.
Nov 30, 2007 | Acer AL1913 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
