Question about Acer Aspire 5100 Notebook
Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
My 4 month old Acer Aspire 5720Z Notebook screen started to flicker yesterday and then when blank. When I adjusted the screen/lid slightly it would flicker and after a number of tries I got the screen back. I used it for over an hour and the OS works fine. I did a virus scan etc. and found no other problems. Today the same thing. (Using it right now) What's wrong with it? Is there something loose or is it a major problem??? I have no time to ship it across Canada to Acer for warranty -- this will take weeks!!!PLEASE HELP!!!
  • 1 more comment
  • CanucksGirl May 29, 2008
    If ANYONE knows of an Acer Authorized Computer Repair Shop in B.C. (Vancouver - Lower Mainland Area) please let me know.
  • Anonymous Oct 13, 2008
    i need network to my pc. acer aspire 5720z
    pleas help me..
  • zy_deco Apr 02, 2009
    My Acer Aspire 4315 does the same thing. The screen flickers, and then
    it goes completely blank white. If I hit Ctrl + Alt + F11 it comes
    back, but it's only a temporary fix. Also, if it helps at all in
    answering my problem: If I attach an additional monitor to my computer,
    it does not go blank when the laptop screen does.
    Problem Solver:
  • 31 Answers
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
sd545
Posted on Jul 20, 2010
Hey, i had this problem about two minutes ago but i fixed it! all you need to do is unscrew the screws on the BOTTOM of the computer, just the ones that are at the front, closest to the screen. the you pry off the section of plastic where all the buttons are. then you should see a connection with a wire leading up to the screen. that connection is most probably loose. push it back in its connector tight and ur good to go! i will probably post a vid on youtube soon on how to do this. any questions, email me at david_cashin@hotmail.com. hope it works!
Posted on Oct 04, 2008
    Scholar:
  • 110 Answers
It sounds like a loose connection or a snapped dry solder joint leading to the backlight. On notebooks and LCD monitors, the screen consists of a florescent panel behind the screen which shines a light similar to a florescent tube through the screen. From your description, it would appear that something is becoming disconnected there.
A local specialist in flatscreen repairs should be able to fix it if it's nothing too major. Try and find one who has a certification to work with Acer to avoid voiding the warranty. If you live in Ontario, where I live, I can do a search to see if I can locate one (please either use the ask button to contact me directly or leave a comment on this ticket) but I have no details of potential repair locations outside Ontario.
Posted on May 29, 2008
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
It is most likely the connector between the screen and the motherboard that is loose/failing. I would check that first, before taking it in for repairs..
  • 119 Answers
If you HAVE any experience with computer hardware you can open it and check the data and power cables that connect to motherboard that they have not come loose or damaged and thus short circuiting your lcd, but you must be aware that unless you have extensive experience you will probably be unable to open your machine in such a way that you do not forfeit your warranty. but the problem is definitely with the lcd connection to the mainboard. If you arent sure send it to Acer to be safe. thanks
Posted on Jun 01, 2008
At times the screen goes fuzzy and flickering is acer aspire 5732z .13 month old bought new
Two or three possible causes for this.First, the cable that runs between the motherboard and screen may be loose.Second, your "inverter" may be going bad,and third,the video chip on your motherboard may be poorly soldered or poorly seated in the socket.
You'll have to take it to a repair shop to find the exact cause of the problem.
Albert Benjamin
May 15, 2011 | Acer Aspire 5735 Notebook
MY acer screen flickers on and off and then when i adjust the screen comes back on but now just keeps flickering. please tell me what the problem is
The problem seems to be related with the inverter wire of your laptop. It doesn't properly connect the mainboard with the inverter-which is on the screen.
Dec 06, 2010 | Acer Aspire 5315 Notebook
Hi my acer 1710 laptop is flickering and the screen goes blank and comes back on and flickers again you can hardly see the screen what could be wrong thank you stuart
It is likely that the backlight for your screen is faulty or needs replacing. This is not a job you can usually tackle yourself, you will need to take it to a dealer to have the unit repaired.
Oct 21, 2010 | Acer Aspire 1710 Notebook
When i'm online, my computer screen flickers then goes blank with a white screen. The computer is still running the screen just goes blank. how can i solve this problem? and sometimes when i turn on the...
Your computer is infected with spywares.You need to scan your computer for spywares from a good antispywares software like Malware byte, SuperAntispyware etc.
Jul 11, 2009 | Acer Aspire 4520-5141 Notebook
Acer 5630 (Windows XP) screen flickers
This is due to your graphic driver. Reinstall your graphic driver will fix the problem.
Jun 07, 2009 | Acer Aspire 5630 Notebook
Laptop screen display
backlight, inverter or loose screen connector into system board
Nov 24, 2008 | Acer Aspire 9300 Notebook
5720Z acer aspire notebook has power light on and another flickering LED but no picture
Hey Rissa
Press the power button until it shutdown and then restart the machine. Press F8 contiuously till it prompt to some option. Choose restore directory......
good luck
zinja
Sep 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
May 29, 2008 | Acer Aspire 5100 Notebook
I have the same problem. It happened to me about half a year ago and reinstalling the OS solved it. So it's by no chance a hardware problem. I have a Acer TravelMate 6291. It must be some kind of a software problem, but don't know which one :-(
May 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5630 with vista home premium
That would be my guess. Since it is still under warranty, take it back and let them mess with it.
Jan 06, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5100 Notebook Logo
649 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
