Question about HP Pavilion a1610n PC Desktop
After pu blew up on hp pavillion t250, the monitor failed to work after new pu installed ,but another monitor works on the pc ok.The power lead to the monitor checked ok but the video lead is fixed so I can not check this.Does this mean a fresh monitor or is there something else to do or check.
  • 669 Answers
You could try the monitor in an other computer. If it does not work, you will probably need a new monitor.
Posted on Nov 28, 2011
I power up and all i get is pc going into power saving mode , no screen ,just black . tried f-8 upon bootup ,but nothing . tower is running and and monitor has power ,just says powering down power saving ,...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 04, 2011 | Computers & Internet
When I power on my HP Pavillion a1220n the power stays on but the monitor is black. Monitor tests OK.
Possibly the video card or settings. If you recieve nothing after turning the monitor on, it is most likely the video card.
Jul 17, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Hp Pavillion 7 running Vista - NO Sound thru Broadband ,No sound CD/DVD ,Operation Clicks etc ok,System says all aok
Try to uninstall and install a new copy of the sound driver.
if it's not working maybe that you need a new sound card because somtime the integrated sound of the motherboard stop working
good luck;)
Sep 09, 2009 | HP Pavillion s7420n PC Desktop
HP pavillion dv9005 no display - works fine on external monitor
If the notebook's video card (which may be on the motherboard) is successfully displaying images on an external monitor it sounds more like a problem with the notebook display or its connections. Probably the motherboard is OK.
Jul 09, 2009 | HP Pavilion dv9000z Notebook
Monitor on HP Pavillion a656x---blew up the power supply--had an extra and installed it--when machine was turned back on--monitor displays "VIDEO CABLE CONNECTED?---what am I going to do----help!!!---
First thing I would do is try the monitor on another system to see if it's in the monitor or computer. Next would be to fire it up and see if you hear a beep from the motherboard. Most consumer pc's will come with a small speaker that sounds on startup. If you don't hear this beep it could be indicitave of a fried motherboard.
But it sounds to me like your video card or onboard video was messed up when the power supply conked out. If it's onboard video you may be able to switch to a video card. If it's a video card you may need to replace it.
Also check to make sure there are no loose wires, that your video card is seated firmly, and that your connectors are all snug. If none of this works then you're most likely looking at a motherboard replacement.
Apr 19, 2009 | Computers & Internet
At start up the screen is blank except for a no signal message
You might wanna try to buy a video card and hook it into a PCI port, sometimes the Integrated video modules fail but the rest of the motherboard works.
Apr 02, 2009 | HP Pavilion a1600n (882780776265) PC...
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
I have new Hp photosmart C4385 all in one scanner, printer, copies. The printer was initially onstalled. Working w/ wireless HP pavillion. It print & copies fine. Scan does not work. When I enter...
I had a similar problem recently... You have to actually install the scanner software. You probably only installed the print drivers, but not the scanner software. If you don't have the CD handy, go to www.hp.com/#Support. In step one select "Download drivers and software (and firmware)". In step 2 enter your model number (photosmart C4385) and then press "go". It will lead you to a page to select your operating system. Follow that link to download the entire CD (large file).
When you are installing the software, make sure to install the scanner software too.
John Lox
Apr 14, 2008 | Computers & Internet
Dark screen
The problems it the inverter is burnt out... Need replace new inverter. contact me, I'll give you a good price. repair@3rd-rocks.com
Dec 06, 2007 | Fuji FP-988D 19" Flat Panel LCD Monitor
HP Pavilion a1610n PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
