Question about SanDisk Sansa Clip MP3 Player
Mp3 player sandisk sansa clip problems
My computer does not recognise my mp3 player but all my other computers do and i have tried everything...such as putting it in hold and holding the center and even holding the volume button.....nothing works i really hope you can fix it
  • 476 Answers
I am not familiar with this model, but I have seen the problem before. It can be caused by the USB controller drivers on the PC.
Follow this link: https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&ctn=SA3124/02&mid=Link_FAQs&session=20080529064055_82.5.155.87&hlt=Link_FAQs
The solution is for a Philips model, but should still work for the Sansa Clip.
The only other caus could be different operating systems on your PCs.
Posted on May 29, 2008
My sansa 4gb clip is not recognised by my computer. The computer will not acknowlege the usb either... My sansa has run out of battery. What can I do????
Hai, i have sansa clip 2gb with the same problem. one ultimate answer i got is Sansa clip uses Media Transfer Protocol(MTP). Sandisk(maker of salsa clip) know about the problem which cannot be solved(the earlier sansa products are to be avoided). There is no solution with the company.
Nov 15, 2010 | SanDisk Sansa Clip MP3 Player
My brandnew sansa clip is recognised by my
you should update new firmware first at http://forums.sandisk.com/sansa/
if it still doesn't work, change another one.
Good luck
Jan 12, 2010 | SanDisk Sansa Clip MP3 Player
My computer will not recognise SanDisk Clip
See if you can download the driver for it on Sandisks site, this should make it possible for your computer to recognize it. You may also want to try a different usb cord, USB cords go faulty quite easily.
Nov 08, 2009 | SanDisk Sansa Clip MP3 Player
Computer won't reconize my sandisk mp3 player
Hi, just had the same problem after restoring my system.
You must disconnect and update your Windows Media Player to Number 11. My reinstall left me at WMP 9 and it wouldn't recognise my Clip. Go to the Windows website, follow the download instructions, and you should be fine. When you plug in the Sansa Clip or MP3, it should recognise it right away. Hope this helps!
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
SANSA 4GB PLAYER
Have you tried updating your Windows Media Player to number 11? this has the drivers for SansaClip. Go to windows website, download WMP 11 and then plug in Sansa and uyour computer should recognise it. Good luck.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip not recognised after formating
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
May 18, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
