Question about Garmin StreetPilot C330 GPS Receiver
Powerless Garmin When I turned the power on it would not stay on. Finally it stopped turning on at all.
  • echofelon May 11, 2010
    It sounds like a battery issue. Does the unit work while connected to USB or AC power?
I think i have the same problem. it shows the boot screen but turns off after about 2 seconds. mine does not work when connected to the USB or AC power either. when i plug it in to the computer, it turns on the boot screen and just stays there. ideas?
Posted on May 31, 2008
We have A Garmin 1300. It works fine for a while then the screen goes blank. We hold down the on button for a LONG while then the screen will come back up and make you go through several screens, but...
Be sure to update the firmware by running the Garmin WebUpdater.
Download and Install WebUpdater.
It is not necessary to unplug the vehicle power cable as the unit will shut down automatically if the vehicle power source is not supplying power after the vehicle is turned off. If the vehicle power cable does continue to supply power, then a manual shut down can be done with the power switch on the nuvi but it is still not necessary to disconnect the vehicle power cable.
Aug 12, 2011 | Garmin nuvi 1300 Car GPS Receiver
When I stop and turn off my car, my Garmin 255W stays on. Hows do I turn it off?
If your GPS is plugged into your power outlet in your car, it just means that the power outlet retains power when your vehicle is off as well. Meaning it is not an "Accessory" power source. Not a big deal, simply slide the power button on your garmin unit to the left. The power button is located on the top left side of the GPS. It is spring loaded so when you slide it to the left, hold it there for a second then it will spring back into place. Just release it and the unit should power down.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
Xbox 360
If this is the same problem I had, mine went for 2 weeks, everyday with me pushing the on button and it stood there like a giant powerless paperweight. Then one day it just suddenly turned on, unfortunately it turned on with RRoD. I'm actually familiar with repairing the RRoD problem, however its been a month now and everything i've tried it just stays on RED Ring of Death.
So sorry this isn't a solution, but if you be patient, maybe yours will turn back on without RRoD
Jul 27, 2008 | Microsoft Xbox 360 Console
Garmin Bluetooth connection problem
The problem is caused when the phone book tries to transfer over. I haven't pinpointed the problem just yet, but it seems that this is the cause.Turn off the address book forwarding and it should work!!
Jul 20, 2008 | Garmin StreetPilot c550 GPS Receiver
Powerless garmin
When leaving the unit not powered up for so long, the internal battery may be damaged. The power supply will not start up if the internal battery is defective.
Sometimes the internal power supply may become defective in this case and must be replaced along with the battery. Contact the manufacture for details about how to get the unit serviced.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Will not stay on
Connect the Garmin using the USB cable to your computer. Turn on your computer and let it boot up. Now turn on the Garmin. Does it stay on? If the answer is yes then the battery is dead. If the answer is no then you have something internally wrong with the Garmin. If the unit is still under warranty then get a RMA and send it back to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
85 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
