Question about Samsung (SP0822N) 80 GB Hard Drive
I have a samsung 80 gb hard disk. It is making sond when going on and causes hanging up.
    Problem Solver:
  • 6 Answers
Sound when u put system on shows that there problem on the motherboard, which may be either RAM,VGA or opening in addon card. I will advice to re-insert the addon cards including RAM first, if this doesn'st solve the problem replace the RAM. If not replace VGA card if not on motherboard. If this doesn't solve the problem, you have to change the motherboard.
Posted on Oct 07, 2010
  • 358 Answers
From what I can deduce here, it seems that you the hard drive
probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is
coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard
drive case and remove the Hard disk from the case, connect it
directly to a system, not externally or through USB this time
around, then get a software called NTFS DOS Professional. It is a
software that works like magic when it comes to hard drive
repairs.
If you know any other hard drive utility, apart from this, you can
also use it. I just recommend this personally because that is what
I use.
Insert it into your PC, start up your CD-ROM and let your system
boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need
to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your
valuable files from it and don't fully rely on the hard drive again
because of the hardware error it has developed. Just keep using it
as a second.
If you cannot do this by yourself, just get a very good technician to
do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
I want to replacement of my 80 Gb hard disk but I unable to find S/N or P/N in your list My hard disk Model :SP0842N P/N:35201QSS900464 S/N : S0DWJ1BP108754 Please help me for replacemest of above...
You do NOT need to buy a new Samsung disk-drive.
You can buy a replacement from Western Digital, or from Seagate/Maxtor, or any other manufacturer.
Take your current Samsung disk-drive to the computer-store, so that they can sell you a new disk-drive with IDENTICAL data/power connectors (either Parallel-ATA or SATA).
Feb 01, 2011 | Samsung (MP0804H) 80 GB Hard Drive
When i start my computer the problem is "hang" how can i solve it????
check the the programs u`ve installed or hardware, antivirus you have installed,defragmenting the hard disk,increase ram size,check for viruses
Aug 05, 2010 | Samsung (SP0822N) 80 GB Hard Drive
Prob with hard disk
IT IS NORMAL FOR THE HARD DRIVE TO BECOME VERY HOT WHILE WORKING. I WOULD SUGGEST YOU TO CHANGE YOUR RAM ONCE AND TRY. HANGING ISSUES ARE MOSTLY RELATED TO RAM.
Apr 10, 2010 | Samsung (SP0822N) 80 GB Hard Drive
My bios see hard but ??
it sounds like its not getting enough power you might have to get a different harddrive or another power supply, if thats not it then its a problem with the harddrive itself.
Apr 27, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Problem in hard disk
hi Kumar, you may not have noticed it in the past, but most drives aren't 100% the capacity that is shown on the box.
There are two reasons for this:
System Overhead use and the way Microsoft counts a MegaByte (1,024,000 bytes) versus how the manufacturers count a MegaByte (1,000,000 bytes).
Hope this helps.
Mar 20, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Drivers
hi..there...maybe you mean the update firmware for your hard disk... but i think only the expart can update the firmware of hard disk 'cause it high risk and can make your hard disk doesn't work anymore.
so same like other if your hard disk works normally it doesn't any driver at all even you us XP or Vista operating system....
Feb 02, 2009 | Toshiba (HDD2D15) 80 GB Hard Drive
Samsung SP0802N 80GB Slave
Go into the control panel. Press administrative tools. Select computer management. Under storage select disk management. Look for the hard drive. Make sure there isn't an additional partition on the drive. If there is you can change and delete partitions on this drive as well.
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard Disk hangs
You have to give it for reairing or buy a new hard disk..
Aug 22, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard Disk formatting Problem
Get the hard drive replaced. It was probably damaged during shipping.
Aug 26, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Samsung (SP0822N) 80 GB Hard Drive Logo
137 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
