Question about Video Game Consoles & Games
I can't get a picture or sound with my ps3. I've tried resetting it several times and unhooking the cables/power supply and rehooking it up w/o any luck
    Problem Solver:
  • 10 Answers
Make sure you are downloading the right type of music pic or video files that might help
Posted on May 29, 2008
RCA Model L40FHD41YX9 Will Not Power on. No Sound or Picture. Found cable from power supply to Backlight inverter connector burned. Replaced cable power supply and backlight inverter and main board.
Going by what all you have changed with no results its sounding like the actual CCFL lights are bad or at least one of them...there should be several sets of wires going to them from the inverter board, you can unhook them one at a time and see if you get some light on the screen, unfortunately though it sounds like the set may be on its way to the recycler. I assume if you look in the back of the set with the lights off you don't see any light.
Nov 08, 2017 | RCA Televison & Video
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
My LG 42LC7D tv wont turn on. The green led lights but no picture or sound
There could be several things going on, I would start with having the power supply checked. I've worked on several LG sets from that time frame that all had bad capacitors in the power supply causing all sorts of issues
Nov 27, 2012 | LG 42LC2D 42 in. LCD HDTV
I have a 2001 pontiac grand am gt. When my car is on and in park a series of beeps comes on. It will beep one then twice then three times then four times and then start over. A friend said it sounds like...
Try unhooking your battery for 15-20 minutes and rehook up with key off when it is unhooked and off when rehooked up . you will have to reset your stations, but it might take care of the problem.
Aug 31, 2012 | Cars & Trucks
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
The amp dont come on but power protecter light is red.
Sounds like something is shorting out and it is in protection mode. Check that the wiring is correct and there are no bad spots on the power wires. Unhook the power before starting your evaluation and leave disconnected until you think you've found the problem then rehook the power source. This will give the system time to reset if it needs to.
May 24, 2011 | Sony XM-2200GTX Car Audio Amplifier
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
I just started using the Belkin N150 after hooking it up it worked for several days than it stopped. I have reset it unhooked and rehooked all connections unplugged power and replugged it in and still...
With what you have mentioned, i will say the following:
Keep pressing the reset button for 3 full minutes by counting on a stop watch. You must see the security(Lock) light going OFF after this reset, else try again, press it tight. After this type reset, unplug the power cable after 1 minute and keep it unplugged for another 1 minute. Plug in back the power cable and check the connections as it was made when it worked. Insert the belkin CD on the primary/base computer and setting it up.
If still its an issue, mail me at:
shanky_arvind@yahoo.co.uk
I ll make sure that your issue is resolved at any cost. Please, do not worry. I ll provide you with service FREE of any charges.
Jan 22, 2010 | Belkin (F5D5231-4) Router
My ps3 powers up, but I get no picture or sound.
Put your PS3 in standby mode (hold the power button until the light turns red) then release, and hold the power button again for about 10 seconds, or until the light beeps a second time. When the PS3 restarts, it should display on whatever it finds plugged in first.
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Dns error on my ps3
easy fix unhook all you wires to your router and modum wait 1min and rehook all wires then wait 3min and try to easy connection under network settings
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
