Question about Cell Phones
My iphone (8gb) is hung, how do i start it only apple logo is on screen. I tried it by rebooting by pressing home key and switch on key simultaneously for 10 sec but no result. I also tried charging it for more than 1 full day but nothing happening. It is still hung and only apple logo on it.,
  • mswaleh2004 Oct 07, 2010
    my red slide bar doesn't appear, its only apple logo. suggest me a solution in which i will not loose my data/photos/videos etc...
  • mswaleh2004 Oct 08, 2010
    do you know any reparing company ? and also if i courier iphone to apple company do they have service to this kind of problems..
  • Cell Phones Master
  • 6,993 Answers
Your iphone is having a software problem. Its operating system files is corrupt that's why it is hanging and will not boot.
You will need to perform a reset in order to solve this problem and if resetting doesn't solve the problem, you will have to update your iphone so that the corrupt files will be reinstalled.
Turn on your iphone, press and hold the Sleep/ Wake button on top of iPhone for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPhone. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
  1. Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
  2. Connect iPhone to your computer.
  3. In iTunes, select iPhone in the Source pane and click the Summary tab.
  4. Click "Check for Update." iTunes tells you if there's a newer version of the iPhone software available.
  5. Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
Apple iPhone DFU mode ( Deep Firmware Upgrade) 1. Turn off iPhone.
2. Connect to mac/pc with sync cable / iTunes.
3. Press and hold HOME and POWER buttons for 10sec.
4. Release only POWER button, but continue pressing HOME button for 10 sec. Now iTunes should detect iPhone in recovery mode.
Good luck.
Posted on Oct 07, 2010
  • Walesarumi
    Walesarumi Oct 07, 2010
    this problem is a bit critical because its a software problem.
    If you don't want to loose your data, then you will have to take the iphone to a repairman, and its will be fixed for you without you loosing your data.
    A data cable, computer, and software will be used to revive your iphone, and this is not what you can do yourself because you don't have the facilities/equipment to do this.
    Good luck.
  • Walesarumi
    loosing your data.
    Good luck.
Hey my apple iphone is hanged i m unable to switch off
Try a hard reset
- Toggle the mute switch 4 times (upo down up down)
- Press and hold the home and power keys for 10-20 seconds until the screen goes black
- Press and hold the power key to restart; release when you see the Apple logo.
Apr 05, 2011 | Apple iPhone Smartphone
My iphone went dead. I hung up from a call and then went to use it again - dead. Plugged in for 1/2 hour and still no juice. Is there a reset button?
Charge your iPhone overnight. If that does not work, try the following resets:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
  4. More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 17, 2011 | Apple iPhone Smartphone
My iphone is frozen at the apple logo screen and wont power down or sync with itunes. How do I fix this?
Have you tried holding the power button and the home key together. Hold until unit reboots and once apple logo appears, release both buttons. If this doesnt work try this below.
Try launching I Tunes on PC without I phone connected. Then make sure I Phone is switched off. Now hold down the home key (square at bottom of screen) Whilst still holding home key plug in your I Phone usb lead. I Tunes should identify you I Phone after few seconds and prompt " detected I Phone in recovery mode" (or similar) it should then prompt 'yes' or 'no' to do recovery. Select yes and let it start. This should resolve this issue as it did on my 3G version.
If still no luck search FAQ's section on www.apple.com
Hope that works/helps?
Oct 14, 2009 | Apple iPhone 3G
Iphoned does not work
Oct 04, 2009 | Apple iPhone Smartphone
Iphone 3g 3.0 stuck on iphone apple logo loading screen
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Aug 27, 2009 | Apple iPhone Smartphone
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
Jul 24, 2009 | Apple iPhone 3G
Hang up
Try to restore using itunes, and make sure you are updated to the newest firmware.
Jul 05, 2009 | Apple iPhone Smartphone
Switching off of the iphone on its own.
Try these resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 19, 2009 | Apple iPhone Smartphone
The iphone 8GB Non 3G Touch screen will not work after the phone
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Dec 18, 2008 | Apple iPhone Smartphone
IPHONE HANG UP
press the home keys and power button simultaneously for about 5 secs... it should reboot. :-)
Feb 02, 2008 | Apple iPhone Smartphone
Cell Phones Logo
100 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
