Question about Husky Husqvarna Chain Saw 240E w 16in bar
Member Discussion on Husqvarna 240e Chainsaw Idle Adjustment I have a new 240e and cannot keep it running. It will start, after many pulls, and one of two things happens. After running for 30 seconds, I will tap the trigger to set the idle and it will promptly idle down and die. Or, I do nothing, and it will idle for a bit and die. Restarts are difficult. I did not get a manual with the saw, so all I have to work with is one I downloaded. Idle adjustment is mentioned, but no indication where this adjustment might be. Thanks
  • Husky Master
  • 2,239 Answers
Its not an idle screw adjustment issue, it is a mixture screw adjustment issue, unfortunatly there is a special tool to adjust the mixture screws, pt no. 530035560 ( available from Hysqvarna dealers ) once you have this tool you can make an adjustment to the L screw on the carb, undo ( anti clock wise ) this screw ten minutes on a clock face ,this will richen the muxture, and should make it more stable on idle.
Posted on Jan 19, 2011
  • Olewillie Jan 19, 2011
    The Husquvana dealers say you can't get the tool, and they can't sell them to you because of federal regullations with pollution....bahhhh....but I bought two of them on E Bay for just a couple bucks. Thanks for the input. I will give it a try
    Ole willie
Show me the idle screw adjustment on a husky 126
Posted on May 14, 2011
1996 jeep Cherokee has a high idle problem
You have asked a vehicle based question in a Chainsaw category. Please try again.
Feb 28, 2014 | Husky Husqvarna Chain Saw 240E w 16in bar
How do you remove the carburetor on a Husqvarna 240e chainsaw?
Remove the handles, then remove four 8MM bolts from the bottom securing the engine case. The entire assembly will then rotate upward,
allowing you to remove the two 8MM nuts and carburetor.
Oct 02, 2012 | Husqvarna Garden
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 55. I put in a new carb, coil,
Preset both needles about 1-1/2 to 2 turns CCW from CW stop. Set H needle first after warm-up. At high speed, engine should 4-stroke with no load, but smooth out with light load(cutting wood). Set idle speed so that it will keep running, then adjust L needle so that engine tries to follow the throttle, but idles fairly smoothly. Readjust idle speed so that the clutch is not trying to drive the chain.
Aug 02, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
Runs but wont idle / Homelite330
Try adjusting the idle. The will be a couple adjustment screws, there will be an (H) and (L) you will need to turn the (L) First tighten the sdcrew completely then turn it 1-1/4 turns. This will be a good to start. Then just turn it small amounts until you get it to idle. Also there should be an idle adjustment you can adjust.
Jun 06, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
My Husqvarna 142 chain saw, new out of the box, starts and runs well enough but left to idle it continually stalls. Any ideas?
The carb needs to be adjusted. Look for 2 adjustments label High(H) and Low(L). Low is the one that you want. Start you chainsaw and let it warm up and turn the L adjustment a until you are able to let it idle on its own. Hope this helps.
Jul 07, 2008 | Husqvarna Husky 165
Husky Husqvarna Chain Saw 240E w 16in bar Logo
1,990 people viewed this question
Top Husky Garden Experts
Steve
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a Husky Garden Expert? Answer questions, earn points and help others
