Question about HP LaserJet 5100tn Printer
Printer hp lesarjet 5100 showing the 52 error
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • HP Expert
  • 217 Answers
Press the "Go"button. If problem persists turn machine off and on. If this does not work you'll have to replace the laserscanner.
Posted on Oct 07, 2010
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
Hp leserjet pro 400 mfp scaner error 52
The scanner initialization did not pass it seems. Try cleaning the glass and white background.
If that doesn't work, the scanner bulb may be faulty - try replacing it.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
How to do if i have error 52.0
Please see the link below for a full explanation and solution
Laserjet 5100dtn 52 0 printer error
Aug 05, 2014 | HP LaserJet 5100 PCL 6
Hp 5100 insufficient memory error
Does it always happen? does it always happen from a particular program? may need to upgrade your memory capacity.
Dec 21, 2012 | HP LaserJet 5100 Printer
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
50 fuser error in hp lesarjet printer
An error 50 on most HP Laserjet printer indicates the fuser has a problem. Most common problem is the heat lamp burned oou. The lamp is not a replaceable item unless you re a top notch technician. The fusing assembly however is usually a relatively easy replacement requireing only twisting of a couple of latches or removal of a couple of phillips screws.
The part # for the fusing asm for the HP LJ 3030 is RM1-0865-000CN.
These can readily be found online for anywheres from $120 to $250.
Dec 18, 2010 | HP LaserJet 3030 All-In-One Printer
Service error
All you have to do is uninstall the RX700
and reistall again. The waste ink counter is in the computer. I found this out when the error lights did not light with the parallel plug out.Off-course you will have to do the same with ssc. This time keep resettting the waste.
Aug 15, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 5100tn Printer Logo
944 people viewed this question
Seeker5211
Seeker5211
