Question about Fuji FinePix S5000 Digital Camera
Camera worked fine in April, I put new batteries in it 100510 and all I can do is view the pictures I took in April. It did let me set the date and time.The lcd and the evf will not turn on when tha camera is turned on, in fact the camera is dead in all modes except the card view. Hope you can help, as this is the only good camera I own. Thanks
  • 1 more comment
  • mcdiver94 Oct 07, 2010
    Thanks for the advice. The lens was extended fully all the time, but I got it to go back in by tapping and jiggling it and turning the camera on and off. Placed the camera, lens down on a cloth and turned it on, and the lens sounded like it was trying to extend but it didn't. Plugged the ac adapter and the usb cable and the DSC comes up on screen no matter which position the swich is in (except off naturally) Could it be that the capacitor or little battery is dead as has happened to some people?
    OK. Thanks again for your solution and for answering so quickly. Looks like I'm in the market for another camera, because the fix is more expensive than the camera is worth. I'll use Fixya again for the next problem.
  • Fuji Master
  • 17,130 Answers
The Program error is due to failure of the Main control system. It will be good to have it checked at the Fuji service as you do not have to run around for spares.
You can remove battery and card replace battery and while switching on tap the lens hood on your palms so as to disengage any dirt or retrieving a mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Since there is no action of the LCD or power it is evident that we need to open the camera to have an overview off what is happening inside as our assumptions can be confirmed only with a voltage check to the main processor board. Once we are confirmed that the power goes into the main unit without any output from the processor, the suspected part can be the processor unit.
If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 08, 2010
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Oct 07, 2010
  • Andrea Lock
    Andrea Lock Oct 07, 2010
    Hello
    Thanks for coming back to me.
    Well, you can never rule out anything, but, as i read your original question, i knew exactly what the problem was. And, even still after your post, i still suspect that your guidance pins in the lens barrel is out of place.
    Now, as is suggested in the original answer, if the answer given does not work, the best will be to take your camera to your nearest repair store. Even if this is a capacitor problem. This is not something i would suggest that you try to fix by yourself. If this is not done correctly, you can damage the camera beyond repair.
    I really hope this can be of help.
    Please feel free to contact me if you need any further assistance.
    Kind regards
    Andrea
Pentax k2000 won't save time and date
In most modern cameras is a little rechargeable battery, that keeps the clock ticking. If your camera was a long time without power, perhaps this battery has died. I would buy a new set NiMH rechargeable or recyclo batteries, because they have a bit less capacity, but can hold power for as long as a year. Then charge them and leave the rechargeable batteries in your camera. Keep your fingers crossed, perhaps the little clock battery will be revived?
Feb 15, 2014 | Pentax Cameras
I TOOK PICTURES AND THE DATE WAS NOT SET CORRECTLY NOW THE STAMP ON THE PICTURE HAS THE WRONG DATE HOW DO I CORRECT IT ... I DO NOT WAS TO PRINT ANY OF THESE WITH WRONG DATES PLEASE PLEASE HELP!!!!
You cannot change the dates on the taken photos using the camera.
Copy the pictures to your PC, and use a graphic editor to put the new date.
It is a very difficult task to change the date displayed. Therefore insert a button-like graphic on top of the date and put the correct date over that.
Sep 19, 2011 | Kodak EasyShare M1093 IS Digital Camera
Flash setting doesn't work
Does your camera gave a small battery in place somewhere that is used to maintain the date and time settings? (it is generally a watch battery type small flat silver disk.) You should not have to reset time and date after each battery change.
Many digital cameras eat up batteries quickly, especially when using the flash alot., that is why it is important to use good quality rechargeables whenever possible.
Jun 19, 2009 | Fuji FinePix 3800 Digital Camera
How do I GET DATE AND REGULAR TIME, NOT MILITAY TIME, ON PICTURES
Turn camera ON
Scrol with Menu Burtton to time and date .
Scroll far right and set time and date.
When taking pictures put on the Beach or Snow mode.
Vitally
May 10, 2009 | Kodak EASYSHARE M1063 Digital Camera
The only functioning modes are the picture viewing & set up modes
Have Sony DSC-P73 with exact problem. Only turns on in SETUP mode and when switches to all other modes camera shuts off usually with lens extended. Have tried new batteries - new memory stick - new everything and nothing helped. I just took out the batteries and attached the AC ADAPTER and all works perfectly now so problem is with either batteries - battery compartment or battery connections. As long as you do not need a "PORTABLE" camera, using AC Adapter solves this problem :)
Dec 25, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Lumix DMC-LS70 won't take pictures
U have a sick puppy there. May not be cost effective to repair.
Jun 25, 2017 | Panasonic Lumix DMC-LS70 Digital Camera
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Aug 30, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
Lost Pictures
I'd recommend that you follow this digital camera photo recovery guide as soon as possible to recover those pictures.
Mar 25, 2008 | Nikon Coolpix 4600 Digital Camera
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Button don't work
One of the buttons is constant presset in.
Under the button is a metal membrame, sometimes it happens by to mutch force the membrame is defect, it doesn't popup again.
Try to find out witch button doesn feal good anymore, can you work without it ?(for example left macro), open camera and remove membrame.
LKet it repait by fuiji ? a least € 100,-.more than new....
Nov 12, 2007 | Fuji FinePix A310 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
