Question about Dishwashers
Indesit ide 750 A10 error code - Dishwashers
4 Suggested Answers
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
IFIXALL
  • 868 Answers
SOURCE: indesit IDE 1005 error code
Replace the control board
Posted on May 22, 2008
  • 70 Answers
SOURCE: my dishwasher is showing error
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Posted on Jun 12, 2011
Code fo3 on a Indesit washing machine
try here
https://www.northlondonappliancerepairs.co.uk/error-codes/indesit-error-codes/error-codes-for-indesit-washing-machines.html
Mar 14, 2018 | Indesit Washing Machines
F06 error on indesit WD 61451 washing machine
Could be the program select error, but why not check all error codes and save them on the Indesit site yourself.
Error Codes Indesit Service
Feb 25, 2015 | Indesit Washing Machines
A10 code Indesit Dishwasher DSG573
A10 is a heater fault check heater or look for poor connection on module normally the pink or blue wire
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
Installed new WD HDD (160Gb) into Toshiba Satellite A10-S167. Entered BIOS edit, but can't get laptop to recognize the new HDD (which replaced a smaller, failed HDD)
Shouldn't have any problems on the A10 series working with a 160GB drive, so long as it's an ATA/IDE type with a 44-pin connector. If it's not recognizing the drive, could it be that the pins were not precisely lined-up with the IDE connector? I'd remove the drive, make sure the pins are still all straight, reinsert it into the HDD compartment and see if it makes a difference.
Aug 31, 2011 | Toshiba Satellite A10-S167 Notebook
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
Fault code A10 on indesit dishwasher, how do I fix it?
A10 fault indicates heater open circuit fault. Problem either heating element, or control board. Test element for correct continuity and resistence, if OK, replace controller
Aug 07, 2009 | Indesit Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDE 1005 error code
May 22, 2008 | Dishwashers
Dishwashers Logo
520 people viewed this question
Top Dishwashers Experts
