I have a pink Logik DAB dax101p radio but cannot set the pre tunes to what I would like? Please help I know it will be so simple it will make me mad! Thanks
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
SOURCE: logik dax dab mp3 player
Look here, it should help:
http://support.thetechguys.com/layout.aspx?CatID={6e93bd13-7e35-4d6c-b6d0-9ef772b186f4}&ID={f847278f-41cf-4a00-9874-93770b7a1905}
Posted on Jul 23, 2008
  • 1348 Answers
SOURCE: Mains hum on Ferguson R121 DAB radio
wrap aluminum foil around the power cord
Posted on Jul 19, 2009
SOURCE: Have bought a Technika DAB
To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
Posted on Mar 01, 2011
Logic L55 dab 15 radio how do I tune it as do have the manual
LOGIK L55DAB10 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > Brands > Logik Manuals > Radio > L55DAB10
View and Download Logik L55DAB10 instruction manual online. ... DAB RadioInstruction Manual L55DAB10 L55DAB10_IB_110810_Zell.indd 1 10/08/2011 ...
Dec 16, 2015 | Audio Players & Recorders
Logik dab radio L2DAB12
I need a user manual for my radio logik L2DAB12 please help
May 15, 2014 | Audio Players & Recorders
To tune lowry dob radio model nogsdab1001
Lowry Dob or DAB radio???
If the latter, you don't have to tune it at all, DAB is a Digital Audio Broadcast radio and when you first plug it in you should find a button somewhere with setup or search on it, press this and Voila, you have magic happen.
Try it, it's great.
I hope this helps and by the way it's not a CB/2-way radio if it's DAB.
Cheers,
Peter
Feb 21, 2013 | Radio Communications
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
Feb 20, 2013 | Chrysler Cars & Trucks
Logik LPDAB10 DAB Pocket Radio wont switch on stays on welcome how do I reset it
I had the same problem and the answer is use cheap batteries. Don't use the expensive battery. Hope this helps
Jan 20, 2011 | Televison & Video
Logik dax dab mp3 player
Jun 23, 2008 | Audio Players & Recorders
Feb 22, 2008 | Audio Players & Recorders
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
69 people viewed this question
 Grubhead
Grubhead
