Question about Sony VAIO PCV-RS720G (027242658103) PC Desktop
Brand new sony vaio, the fan has started working in overdrive and will not shut down help
  • MrCloister Oct 07, 2010
    Does the fan kick in right after you start the PC up? and does it stay in "overdrive"
    There are two things I would guess are up with it.
    1. Your PC is full of dust, to resolve this you need to blast the dust out with compressed air. sometimes a small hoover could also help, an industrial air line would be great but a can of spray air would probably do to start.
    2. Your fan has been set to always go fast in the Bios. going into the bios on startup and changing options there would help in this case.
    Could you see if you can find out which fans are running high?
    Thanks
    Problem Solver:
  • 7 Answers
The fan is most likely dirty and it is mostly likely the fan on the CPU. Get a soft bristled brush and a can of compressed and clean it out. It will quiet down.
Posted on Nov 10, 2010
What's your problem?My Sony VAIO VPCF132FX/H keeps shutting down due to heat
- Yes Jim. The Problem is Dust. You have to open the laptop case and Removed the Dust Present in FAN. If its under warranty, you can Visit the SONy Servie Center, They will do it.
Jul 24, 2012 | Sony VAIO F Series Grey Notebook Computer...
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
One time cooling fan caused sony laptop to black out. right now, changing desktop picture caused cooling fan to start heating up. shut down some opened programs and it is all right. what is the problem?...
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Apr 26, 2011 | Sony VAIO PC Desktop
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Vaio shuts down suddenly, not due to battery
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 16, 2010 | Sony VAIO Notebook
Vgn-cs26m will not start,boot into windws and shuts down
kevin,
Is this the pink sony vaio? Looks familiar . . .
The problem with this model of sony vaio is the fan that's why it keeps on shutting down after a few minutes. If you notice there is no activity on the internal fan. The internal fan and heat sink is on the same module.I have already replaced the fan on one of this models and its now working just fine.
just look for a spare fan on ebay . . .
hope this helps . . .
Apr 05, 2010 | Sony VAIO VGN-CS260J/P Laptop
Sony VAIO VGNCS215J Logging Off Problems
Update the O/S
Check your power options in control panel,
Adjust for your lifestyle.
Hope this helps
Regards
Apr 19, 2009 | Sony VAIO VGN-CS215J/W Notebook
Brand new vaio, month old at most, suddenly wouldnt let me do anything. shut down, and now everytime i turn it on, black screen with load continuous beeping!!! help!
That sounds like an hardware problem, like momory.
Since it is new, i suggest you take it back to the store and have it replaced or fixed.
Good luck to you
Dec 11, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Problem Sony VAIO PCV-W510G
maybe this can help you,please try to replace the fan or you can also clean it.. http://www.docs.sony.com/release/PCVW510G.pdf
Jul 05, 2008 | Sony VAIO PCV-W510G PC Desktop
Sony VAIO PCV-RS720G (027242658103) PC Desktop Logo
77 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
