Question about Intel D845GVSR Motherboard
After shutdown sys is not booting - Intel D845GVSR Motherboard
  • Intel Master
  • 27,725 Answers
If your computer starts wont boot into windows
test your PSU power supply unit
One bad lead can cause a computer lots of problems
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Oct 07, 2010
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Computers & Internet
A problem has been detected. i boot it from cd and after the windows setup it displays" a problem has been detected and windows has been shutdown to prevent damage to your computer the problem seems to be...
If you're running Windows XP (Any version) or Vista open the link provided below for instructions on how to repair you're master boot sector other wise known as fixmbr; http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/
Read everything.
Mike
Jun 03, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Boot system error, insert boot disk..
If you are using windows,System files(boot.ini, config.sys, autoexec.bat, msdos.sys, io.sys) might have lost or corrupted accidentally. You can fix it easily by connecting your hard disk to any other system having windows. boot from the host computer's operating system. open my computer, select folder options from tools menu. select second tab (view) scroll down to uncheck "hide protected operating system files (recommended)" and click ok. now go to C drive. Now you can see the system files mentioned above. copy all the required files to your hard disks partition's root and shutdown. now take out your hard disk and connect to your computer and re-start.
another method is to make a bootable pendrive (visit: http://www.esnips.com/doc/0882f54e-3445-41b6-830d-e43fd7d02dc2/Active+Password+Changer+-+Boot+Disk+Creator
to download application to make bootable pendrive.) copy all the system files from another computer. boot your system using this pendrive and select option 3 to exit from the menu to prompt. copy all the files to your OS partition and now reboot. this will solve your problem (you may need to change bios setting to boot from usb). for further details you can contact av_balajee@yahoo.com
Mar 01, 2010 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Hi my dell inspiron 220 says a problem has occured and windows has been shutdown to prevent damage. problem caused by file usbhub.sys. driver unloaded without cancelling pending transactions. wont boot in...
unplug any usb devices attached, press "F2" when you see the DELL logo, go down to boot sequence by pressing arrow down key, press enter, make internal hdd as 1st boot device by pressing letter "U". press enter, go down to POST behavior, press enter, go down to USB emulation, press enter, select off. press enter, press ESC then select save exit then press enter
Feb 23, 2010 | Dell Inspiron 2200 Notebook
Dv6700 boot up problem. power light on. When power on is pressed, the lights in top panel flash once then nothing happens. does not boot. Tried removing battery, reseating RAM nothing worked
Try taking the sys to the BIOS screen and set the defaults after that if the sys doesnt boot up do a system restore by going into the recovery manager page from F11 key on startup to a date when the sys was working fine. IF that doesnt work try enabling the low resolution mode from the advanced boot options from F8. If this doesnt work out than finally you will have to run recovery on the sys.
All the best
Feb 09, 2010 | HP Pavilion dv9000z Notebook
Regarding Direct Memory Access
Your disk is probably operating in slow PIO - you can reset it to DMA by reading this article
http://winhlp.com/node/10
Take the Quick solution
Nov 30, 2009 | Microsoft Windows XP Home Edition
After a while it is not detecting any USB devices and the sys not
system problem try to re installed the os.. after that if the same problem..check the hardware
Sep 06, 2009 | Computers & Internet
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Shutdown/Startup repair issue
hi dear
The process NDIS 5.1 wrapper driver belongs to the Microsoft Windows Operating System.
Description: File NDIS.sys is located in the folder C:\Windows\System32\drivers. Known file sizes on Windows XP are 182912 bytes (94% of all occurrence), 167552 bytes.
The driver can be started or stopped from Services in the Control Panel or by other programs. The file is a Windows core system file. The program is not visible. It is a Microsoft signed file. The service has no detailed description. Therefore the technical security rating is 0% dangerous.
This is a common problem experienced by many people. Just Google NDIS.sys and you'll see what I mean. For some it is onboard sound such as Realtech, others it is IRQL conflicts, and for still others such as yourself the NIC card.
One person worked around it by uninstalling the Windows driver and downloaded the manufacturer's driver.
oke
Mar 25, 2008 | Computers & Internet
Intel D845GVSR Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
