Question about Hitachi 50UX57B 50" Rear Projection Television
Help, zenith pvy5265dt
I have a 98zenith pvy5265dt, sound but no picture, fuse fx3461 is bad, and heat shield 1 is getting very hot very fast, what is the problem and how can it be fixed is it can? and what would be the name of this whole board??
    Problem Solver:
  • 26 Answers
The name of the board is usually on the middle or back printed in white, or is on a small sticker on the board. If not, if you call zenith they can probably tell you the part (say your asking for an estimate on what the part would cost) and check ebay or something.
Posted on May 29, 2008
Toner not stuck well on paper and can be easely erased by hand
Sounds like you have bad toner. or fusing area not getting hot enough to fuse to paper. I would try another toner cartridge. If problem goes away. Bad cartridge.
Feb 21, 2014 | Ricoh Aficio Mp4500 Mp3500 Cl7000 Ap3850c...
Picture focus getting worse & worse; now sound becoming intermittent
You are most likely getting bad capacitors in the main power supply as well as the sweep power supplies. Looking at the age of this unit, the cost to replace the power supply, it will cost you about 350 to 450 to repair this set. You MAY ALSO need to replace the High voltage/ sweep board as well. The best way to properly tell would be to call out a factory authorized Zenith repair center. They should have all the boards available to test the TV with. That would also be a bit more to repair. In my opinion, the cost would not justify the repair. Good Luck with your TV set.
Jan 15, 2008 | Zenith IQB55M90W 55" Rear Projection...
Heat shield rattling is it ok if I just take it off with out replacing it ?
heat shield could be broken or loose missing screws to hold it in place.NO bad idea DONT remove heat shield it protects other components from heat damage.heat shields also protect vechicle floor board from getting too hot causing fire.
Sep 12, 2013 | 2001 Mazda Protege
BLACK SCREEN,JUST SOUND HELP!!!!!!!!!!!!!!!!
a lot of those get a bad Y board or panel driver. sometimes both.
Apr 08, 2010 | Zenith Z42PX2D Television
Tv won't turn on
I donot know the model # but if it is 11 years old, it is the classic we have a lot of bad caps. If the fuse is good, this is all you need. Maybe 10 or 15 of them can be found with the cap check. If the fuse is burned, replace the H.O.T., the poweline reg. and that small voltage reg just two inches away. [other side of heat sink] See the NTE cross ref bible for semiconductor replacement. The resistors are usually good. Caution High voltage inside!!!!!!!!!!
Sep 03, 2009 | Zenith Televison & Video
Does a heat sheild of some type go on the starter. Seems if starter gets to hot the truck will no longer start and will have o wait for cool down before starting the vehicle again?
Sounds like the starter is going bad.1) You can fabricate a shield yourself out of tin or thin sheet metal. Make sure you do not come in contact with the positive wire going to the starter when installing. 2) you can replace the starter -recommended- then add a shield to prolong the life of your new starter.
Jul 28, 2009 | 1991 Toyota 4Runner
Engine 1 fuse keeps blowing when you turn the key
sounds as if you have a power shortage in the van. first establish what fuse keeps blowing this will help in narrowing down the short.once short is located check all connections ,wires,and plugs.
Jul 12, 2009 | 1999 Chevrolet Express
1994 Chevy Silvrado Starter Problem
It’s your solenoid that is getting hot and the engagement washer inside is what is sticking. There is some heat shield material you can get from the auto parts store to shield you solenoid.
Jun 23, 2008 | 2000 Chevrolet Silverado
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
Sound No Picture
The FBT (high voltage transformer) is bad.
Sep 06, 2007 | Zenith A56M91W 56" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
